Greetings, HomeSeer Enthusiasts.
I have two Z-NET controllers (primary/secondary) covering a 50+ node network. During basic optimization (no route changes), the second Z-NET crashes (i.e., HS3 loses contact) consistently in the process at one node (a normally functioning Leviton dimmer). I have tried restarting HS3 and the Z-NETs, to no avail. This is on HS3 3.0.0.368 (Linux) with Z-Wave 3.0.1.152, Z-NETs are 1.0.23.
Take a look at the abridged log output:
11:13:50:2024:Starting Z-Wave node neighbor update for all Z-Wave devices...
11:13:50:4451evice Basement IT Room Z-NET-MainHouse1 (1) will not be optimized because it is a HomeSeer controller.
11:13:50:4483evice Second Floor Family Room Z-NET-MainHouse2 (33) will not be optimized because it is a HomeSeer controller.
11:13:50:4504evice First Floor Dining Room Motion (62) will not be optimized because it is a non-listening device. Please use Optimize from the device properties for this device after placing the node in an awake state.
11:13:50:5835:Optimize complete wait time is 2:59
11:13:50:5842:There are approximately 51 nodes to optimize.
11:13:50:5851:Optimizing node 2 (Basement Gym Ceiling1)...
11:14:17:6481one.
11:14:17:6632:------------------------------------------------------
11:22:53:6719:Optimizing node 18 (Second Floor Family Room Ceiling)...
11:23:01:6738one. The optimization was not executed as the node cannot be reached.
11:23:01:6745:------------------------------------------------------
11:23:01:6755:Z-NET-MainHouse2: Exception transmitting to IP 10.0.3.107: Unable to write data to the transport connection: The socket has been shut down.
11:23:01:6762:Optimizing node 19 (Second Floor Bathroom2 Ceiling)...
11:23:01:6778:Z-NET-MainHouse2: Z-Wave Ethernet at IP 10.0.3.107, connected to interface ok.
11:23:01:9283:Z-NET-MainHouse2: Getting node information from controller...
11:23:06:7922:Z-NET-MainHouse2: Controller Manufacturer: Express Controls, ID=0x2, Type=0x5
11:23:06:7929:Z-NET-MainHouse2: Controller firmware version: 4.32
11:23:07:3145:Z-NET-MainHouse2: Z-Wave Serial API version: 5
11:23:07:3152:Z-NET-MainHouse2: Z-Wave interface node ID: 33, Home ID: CD3B26D6
11:23:07:3166:Z-NET-MainHouse2: Found 54 Z-Wave nodes in interface node ID 33 (Z-NET-MainHouse2)
11:25:09:4571one.
11:25:09:4575:------------------------------------------------------
11:25:09:4578:Z-Wave Optimization of the entire network was aborted early.
I'd like to understand what's going on with the Z-NET when this happens. Are there log files I can tail there?
Thanks, JD
11:14:17:6481one.
11:25:09:4571one.
Thanks, JD
