I have a GE/Jasco 12722 On/Off switch that occasionally does NOT update the 'Last Change' field in my HS3 controller. It's sort of pot luck as to whether or not the field will be updated when I hit the top On toggle on the switch. I have other Innovelli switches installed that do not have this issue. So, I think I can rule out the HS3 controller.
The configuration for the 12722 switch is as follows:
Any help to resolve this issue will be greatly appreciated.
Full Name: Second Floor Office Jasco Switch Binary
Polling: Polling Disabled
Manufacturer:Jasco
Type:0x4952
Listens: Yes
Version: 3.67 (ZDK 4.55)
Firmware: 3.29
Neighbor Count:7
Speed: 40Kbps
Neighbors: 13, 15, 16, 17, 18, 19, 20
Last Working Route: 13 (40K) Set Route:
Uses Interface: Home (1) Basic Type: ROUTING SLAVE, Generic Type: SWITCH BINARY, Specific Type: POWER SWITCH BINARY
Command Classes:
Supported: Switch Binary(V 1), Switch All, Powerlevel, Configuration, Version, Manufacturer Specific, Node Naming
Manufacturer:Jasco
Type:0x4952
Listens: Yes
Firmware: 3.29
Neighbor Count:7
Speed: 40Kbps
Command Classes:
