Attached is Version 2.3.0 of the SqueezeBox plug-in.
Changes:
Beta Update V2.3.0.1:
Beta Update V2.3.0.2:
Beta Update V2.3.0.3:
Beta Update V2.3.0.4:
Update V2.3.0.5:
Beta Update V2.3.0.6:
Changes:
- Player HS2 devices are not automatically created as players are discoverred. For each player, you enable or disable HS2 device creation or defletion from the plug-in status page. After upgrading, you will need to navigate to the plug-in status page to enable devices for players.
- Once devices have been created, the initial device names can be overwritten using custom device names.
- HSTouch notifications are collapsed and sent to HSTouch at the rate specified by the setting "Player Monitoring Interval".
- There is a new configuration option in the plug-in configuration page to notify HSTOuch of player's current track position (Time) changes. If the current track position (Time) is not used in any screen, disabling it decreases overhead.
- There is a new configuration option in the plug-in configuration page to make the plug-in the Primary Speak Proxy or not. If enabled, the plugin-in calls hs.SpeakProxy to tell HS2 to speak. If disabled it will not notify HS2 and another Speak Proxy plug-in should do so.
- When a Speaker Client is specified in the plug-in "Speaking" configuration, only the text spoken for this host will be played on Squeezebox players. As before, if WaveIn is used, it specifies the speaker client that is to stream audio to LMS.
- Internal implementation changes to related to LMS and player status update as well as related to speaking text on players.
- Fixed issue when a player reconnects after after an LMS forget message
- Fixed issue related to speaking text to a Speaker Client not matching the one defined in the plug-in configuration.
- Logic changes when a player disconnects
- Logic changes when processing TTS messages (With this version the last 10 wav/mp3 files are kept).
- Fixed playing Spotify Radio stations with Music API PlayMusic
- Various other fixes.
- After TTS announcement, restoring song time as it was prior to TTS including when when player was paused.
Update V2.3.0.5:
- Release version of 2.3.0.4 sent to Updater. Removing beta version from this thread as it is now in the updater.
- Extended maximum number of IR signals to 256 (was 64 in prior versions).
- Removing attached version from this thread since available via updater.
