PLCBUS plugin for HomeSeer 3 - V3.0.1.0 - Release
    #61
    Stipus , is that possible to add a Device in the Scenes without program it ?
    Since I already setup the Scenes already by other program. I just want to add the device in the Scenes but no need to program it.
    Now , once I press "Add currently On device as On" , it will program the scenes address.
    Kevin Lo
      #62
      Dear Kevin,
      There is no option to add a device to a scene without programming the scene.
      But if the device is already in a scene, it will not accept a second programming.
      So you can:
      - switch all user devices off
      - send the scene ON address with a 4034
      - In HomeSeer, POLL each scene device so that the Plugin knows the dim level.
      - Add all 'ON' devices to the scene.
      --> The plugin will record the dim level for each device
      --> The plugin will send a scene programming PlcBus packet
      --> But the devices don't change their programming (ramp rate won't change), because they are already setup for this scene address.
      stipus
        #63
        Did anyone try the PLCBUS plugin under Linux ?
        I don't have a Linux box... I installed mono on a iMac 27 running latest OSX... HomeSeer and the plugin did run fine... I marked the plugin as Linux compatible but I don't really know...
        I think it should work ...
        Anyone ?
        stipus
          #64
          Stipus , I just buy the HS3 Pi version for Raspberry Pi. I will test it soon and let you know is that work .
          By the way , any update for the bug of HS3 that running muilt PLCBUS plug-in , but only the first active plug-in work when you create the device ?
          Kevin Lo
            #65
            Kevin Lo
            I find that HS3 Pi version didn't allow us to install 3rd party plug-in.
            So that I already submit an request to get my refund.
            I think I need install the HS3 Pro in a full Linux machine for testing.
            According to here , something should need to change for support Linux :
            http://www.raspberrypi.org/forums/vi...p?f=37&t=80833
            The author that wrote the plug-in (driver) would need to port it to Linux. This is not terribly difficult.. in some cases, just the "/" characters need to be changed to "\"
            Then, the .exe plug-in would need to be rebuilt as a .dll format (again, not difficult)
              #66
              Dear Kevin,
              I tested the plugin before release with mono, and it worked.
              First it didn't work, and I had to change the way the serial port communication is handled.
              stipus
                #67
                Great plugin
                I am testing it out if it works for me
                I have added a device PCIBUS appliance for a lamp (as it doesn't have a dimmer) and I am getting multiple "sends" for lights on or off
                the transmitter is sending the commands about 5-6 times, why?
                  #68
                  Originally posted by stipus View Post
                  Dear Kevin,
                  This is a bug in HS3. I cannot do anything to fix it myself. I have filled an official bug report to the Homeseer bugzilla...
                  To create a device in multi-instance mode, you have to shut down other plugin instances first.
                  I hope HST will find some time to work on this problem...
                  Best regards,
                  Stipus
                  It looks like HST fixed the problem in HomeSeer 3.0.0.123.
                  I can't find the link to download this version, but I'll test as soon as I can.
                  stipus
                    #69
                    Anyone ?
                    Stipus ,
                    I install a Raspbian on Raspberry Pi and then install Mono , I test 1141USB and 1141NET , both work fine. I test attach 1141USB on Pi and open another two instance for connect 1141NET via TCP , both work.
                    (But Homeseer for Raspberry Pi version not work. You need to install Full HS3 Linux on Raspbian)
                    Kevin Lo
                      #70
                      Stipus , did you test PLCBUS dimmer module on HST ?
                      I can control the PLCBUS dimmer on the web UI's slide bar. (I can see in the Log , it can get the control : CAPI handler)
                      But on HST , I create a slider and select the "Status Tracking" to the PLCBUS dimmer device. But it don't work. The log didn't show it can trigger the event for the CAPI handler
                      Any idea ?
                      Kevin Lo
                        #71
                        I think that is the bug of HS3 and HST.
                        http://board.homeseer.com/showthread.php?t=164746
                        I run the script and change the PLCBUS dimmer device to CAN_DIM = FALSE
                        Then the HST's slider work......
                          #72
                          Thanks a lot for your report Kevin !
                          It's very interesting to know the plugin runs fine under Linux, and Raspbian on Raspberry Pi.
                          I'm sorry for the HomeSeer bug with HS-Touch and the CAN_DIM property !
                          I understand there can be bugs within HomeSeer... but this was reported in December 2013, and it looks like something so important such as being able to DIM a light, is not fixed yet in August 2014... !
                          On the other HomeSeer bug with multiple plugin instances, I can see there has been some work during the last few weeks, but it's not 100% fixed in HomeSeer 3.0.0.125
                          http://bugzilla.homeseer.com/bugzill...ug.cgi?id=1673
                          stipus
                            #73
                            Can I use license of PLCBUS plugin HS2 with HS3 ?
                            Hi Stipus,
                            I use PLCBUS plugin HS2 for many years and I have a license for HS2. Can I use it also for HS3 ? or i have to buy a new one?
                            Thank you
                            Stamatis
                              #74
                              Hi Stipus,
                              Great job on the HS3 PLCBUS plugin. The stars were finally aligned for me and I've finally finished my HS2 to HS3 migration. I recreated 70+ PLCBUS devices on the HS3 system and it probably just took an hour or so for that part, so that wasn't so painful as I initially thought.
                              Some questions and comments:
                              1. (Re: very slow scene issue, I've created a separate thread for that) : http://board.homeseer.com/showthread...24#post1169424
                              2. How can I see a listing of device codes:names? I can only see the list of unused device codes ('Display Available Codes' in the Add New Device screen)... OR a list of the device names (but cannot see the device codes) in the Device Management screen. The old PLCBUS plugin had handy table of codes:names.
                              3. How to change the auto-poll timer?
                              Cheers
                              Originally posted by stamatis View Post
                              Hi Stipus,
                              Thank you
                              Stamatis
                              There is a special discounted price to upgrade from HS2 version. Just punch in your HS2 license number when you purchase the HS3 version from the store.
                              HW: HS3 w/ Win8.1 on ASRock C2550d4i. Digi AnywhereUSB, Hubport, Edgeport, UZB, Z-trollers, PLCBUS, SONOS, GC-100, iTach IP2SL, WF2IR, IP2IR, RFXtrx433, Harmony Hubs, Hue, Ademco Vista 128BP, NetAtmo, NetAtmo Welcome
                              Google Search for HomeSeer Forum
                                #75
                                Originally posted by LeoS View Post
                                Hi Stipus,
                                I'll check this thread
                                I don't understand why you don't see this list in the main HomeSeer screen.
                                In the HomeSeer device list, you should see all PLCBUS modules with names and device codes.
                                I think there is a parameter in the hspi_plcbus.ini config file
                                I don't have access to my computer and can't give you the exact parameter right now.
                                If you can access the hspi_plcbus.ini config file for HS2, you may copy the parameter to the HS3 config file, then restart HomeSeer 3.
                                Cheers
                                stipus
