How do I download the HS3Pro software?
    I've gone through the process to get the license information for the HS3PRO trial (several times) and still can't find a link to actually download the software. It's like an endless loop of pdfs and other documents that never actually download the software. Very frustrating. I've purchased lots of software on the net, and never gone through anything like this.
    There are no actual download links for HS3PRO on the download page!
    https://homeseer.com/current-downloads/
    Where can I go to find a download link?
    The green boxes that say "download HS3"
      Thanks for the quick reply, but there are no such boxes for HS3. Here is what I see:Click image for larger version
      I get this even after registering for the license.
        What URL are you trying to use? I go straight to the one in the previous post and the downloads are right there.
        Windows:
        https://homeseer.com/updates3/SetupHS3_3_0_0_368.msi
        Linux:
        https://homeseer.com/updates3/hs3_li...0_0_425.tar.gz
        Raspberry Pi2/3
        https://www.homeseer.com/updates3/hs3pi3boot.zip
          Windows:
          Linux:
          Raspberry Pi2/3
          Thanks so much. That should do it. As I mentioned, and as shown in the screen shot I posted, all I get is links to get a license. Those buttons both open up a new window that allows you to purchase a new license. No buttons that link to the URLs you posted here. The HS3Touch section includes download buttons for Designer / Client, Android Client, and iOS Client. But both of the green buttons above that for Windows/Linux and RP only allow you to register for licenses. Very odd that you can see the download buttons, but I cannot.
            I think you may have a cookie in your cache from the store.
              That's what I thought as well. But I deleted all my cookies and cleared the cache, and still no download buttons.
                Its not you, the site seems broken. Downloads do not seem to be available. The seem to have made a change where you have to sign up for a temp license via the checkout, but then did not put a way to download the file...
                Someone I guess will figure it out
                  Ditto for me, couldn't download new version
                    Download the latest Windows release version from this link:
                    https://homeseer.com/updates3/SetupHS3_3_0_0_425.msi
                    cheeryfool
                      Thanks for the links guys. I was getting the same endless loop and no actual installer. Not what I needed after my Home controller PC just died. Trying to get this new one working and couldn't even get the dahm software.
                        HS3 and HS3 beta links are also found in this forum under the release notes of either Beta or Regular.
                        https://forums.homeseer.com/showthread.php?t=176440
                          This should be fixed by Monday morning as the download like was accidentally removed.
                            Installing HS3Pro onto an Rpi2 with no instructions.
                            I've got the HS3Pro file (hslinux_hs3_3_0_0_435.tar) from https://homeseer.com/updates3/hslinu...0_0_435.tar.gz which I was told can run on the Rpi2 but there are no instructions. so I copied the contents of the file onto a 32gb uSD card and put it in my Rpi and powered it up. The green SD card activity light has been on solid now for 20 mins and nothing coming out of the HDMI port. Not sure if it's locked up or doing something. No browser response for HS3Pro or Recovery console. I am going about this the right way?
                              The HS3 Pro Linux download is a compressed HomeSeer directory that will run anywhere on your RPi2.
                              That said the Zee2 places the HomeSeer directory in the /usr/local/HomeSeer directory.
                              To install manually then you would:
                              1 - ssh to your RPi2 or use a terminal window on the RPi2 xwindows GUI.
                              2 - sudo su
                              3 - cd /usr/local
                              4 - type:
                              wget hxxps://homeseer.com/updates3/hs3_linux_3_0_0_435.tar.gz
                              change the above xx to tt when using the command.
                              5 - type:
                              tar xavf hs3_linux_3_0_0_435.tar.gz
                              6 - type ls
                              7 - you will see a HomeSeer directory
                              8 - for time bean manually start homeseer by typing:
                              ./go
                              9 - leave the terminal window open for time bean and play with the homeseer GUI
                              8 - next you will need to autostart it.
                              9 - easiest way to do this is to edit the rc.local file to start Homeseer.
                              10 - type nano /etc/rc.local
                              11 - add this to the end of the file and save it.
