I've tried doing a rescan multiple times. Here is the last time. Z-Wave plug-in beta .210.
Apr-24 21:56:58 Z-Wave Warning (2) Received a METER class report from node 73 for MT=Electric_meter, MST=5, but the corresponding child device could not be found. Apr-24 21:56:56 Z-Wave Adding Node 73 Z-Wave Watts 1 as an Energy tracking device. Apr-24 21:56:52 Z-Wave Adding Node 73 Z-Wave kW Hours 1 as an Energy tracking device. Apr-24 21:56:26 Z-Wave The clock on Node 73 Z-Wave Aeon Labs Switch Multilevel is currently set to today being Tuesday at 21:56. Apr-24 21:56:24 Z-Wave Configuring Aeon Labs device Node 73 Z-Wave Aeon Labs Switch Multilevel (73) to report Group 2 data at 5 minute intervals. Apr-24 21:56:24 Z-Wave Configuring Aeon Labs device Node 73 Z-Wave Aeon Labs Switch Multilevel (73) to report Group 1 data at 10 minute intervals. Apr-24 21:56:23 Z-Wave Configuring Aeon Labs device Node 73 Z-Wave Aeon Labs Switch Multilevel (73) to report Meter and Sensor data in Groups 1-3 to HomeSeer. Apr-24 21:56:20 Z-Wave Getting association information for Node 73 Z-Wave Aeon Labs Switch Multilevel Apr-24 21:56:15 Z-Wave Assigning return route from node 1 to Node 73 Z-Wave Aeon Labs Switch Multilevel Apr-24 21:56:14 Z-Wave znet5855: Adding association for Z-Wave device Node 73 Z-Wave Aeon Labs Switch Multilevel (Node 73, Group 2, Endpoint 2) to HomeSeer Apr-24 21:56:10 Z-Wave Assigning return route from node 1 to Node 73 Z-Wave Aeon Labs Switch Multilevel Apr-24 21:56:08 Z-Wave znet5855: Adding association for Z-Wave device Node 73 Z-Wave Aeon Labs Switch Multilevel (Node 73, Group 1, Endpoint 1) to HomeSeer Apr-24 21:56:08 Z-Wave All associations for node 73 have been retrieved successfully, it supports associations on these groups: 1, 2. Apr-24 21:56:08 Z-Wave Node 73 Association Group 2 can have 5 associations, and currently has 1 Apr-24 21:56:08 Z-Wave Node 73 Association Group 1 can have 5 associations, and currently has 2 Apr-24 21:56:06 Z-Wave Getting association information for node 73 Apr-24 21:56:06 Z-Wave Node 73 Meter is Supported for Electric_meter, Type ELECTRIC_A, Scale is INSTANT Apr-24 21:56:06 Z-Wave Node 73 Meter is Supported for Electric_meter, Type ELECTRIC_V, Scale is INSTANT Apr-24 21:56:06 Z-Wave Node 73 Meter is Supported for Electric_meter, Type ELECTRIC_W, Scale is INSTANT Apr-24 21:56:06 Z-Wave Node 73 Meter is Supported for Electric_meter, Type ELECTRIC_kWh, Scale is ACCUMULATED Apr-24 21:56:05 Z-Wave Node 73Supports Color Capability ID Blue Apr-24 21:56:05 Z-Wave Node 73Supports Color Capability ID Green Apr-24 21:56:05 Z-Wave Node 73Supports Color Capability ID Red Apr-24 21:56:04 Z-Wave Processing Information for Node 73 Multi-CHANNEL Command Class of SWITCH_COLOR, Endpoint 2 Apr-24 21:56:04 Z-Wave Processing Information for Node 73 Multi-CHANNEL Command Class of SWITCH_MULTILEVEL_V2, Endpoint 2 Apr-24 21:56:04 Z-Wave Node 73 Meter Instance 1 is Supported for Electric_meter, Type ELECTRIC_A, Scale is INSTANT Apr-24 21:56:04 Z-Wave Node 73 Meter Instance 1 is Supported for Electric_meter, Type ELECTRIC_V, Scale is INSTANT Apr-24 21:56:04 Z-Wave Node 73 Meter Instance 1 is Supported for Electric_meter, Type ELECTRIC_W, Scale is INSTANT Apr-24 21:56:04 Z-Wave Node 73 Meter Instance 1 is Supported for Electric_meter, Type ELECTRIC_kWh, Scale is ACCUMULATED Apr-24 21:56:03 Z-Wave Processing Information for Node 73 Multi-CHANNEL Command Class of METER_V3, Endpoint 1 Apr-24 21:56:03 Z-Wave Processing Information for Node 73 Multi-CHANNEL Command Class of SWITCH_MULTILEVEL_V2, Endpoint 1 Apr-24 21:56:01 Z-Wave Node 73 is a Z-Wave Plus node. Retrieving ZWPlus Info... Apr-24 21:56:01 Z-Wave Node 73 is Z-Wave version: Lib: 4.38 App: 1.12 Apr-24 21:56:00 Z-Wave Node: 73 Controls Class(es): HAIL Apr-24 21:56:00 Z-Wave Node: 73 Supports Class(es): ZWAVEPLUS_INFO_V2, SWITCH_MULTILEVEL_V2, SWITCH_COLOR, METER_V3, CLOCK, MULTI_CHANNEL_V2, MULTI_CHANNEL_ASSOCIATION_V2, SWITCH_ALL, SCENE_ACTUATOR_CONF, SCENE_ACTIVATION, CONFIGURATION_V3, ASSOCIATION, ASSOCIATION_GRP_INFO_V2, MANUFACTURER_SPECIFIC, VERSION, FIRMWARE_UPDATE_MD, POWERLEVEL, DEVICE_RESET_LOCALLY Apr-24 21:56:00 Z-Wave Syncing Z-Wave nodes with device list... Apr-24 21:56:00 Z-Wave Found 38 Z-Wave nodes Apr-24 21:56:00 Z-Wave Getting Z-Wave node list for network D1E956D6...
