Go Back   HomeSeer Message Board > Security Systems Plug-ins > Security System Discussion > HAI/OMNI Panel for HS3 Plug-in (rmasonjr)
HAI/OMNI Panel for HS3 Plug-in (rmasonjr) Discussion about Rob Mason's HAI/OMNI Panel Plug-in
Closed Thread
  #41
Old April 16th, 2018, 11:40 AM
Daweeze's Avatar
Daweeze Daweeze is offline
Seer Deluxe
Quote:
Originally Posted by Daweeze View Post
Confirmed that upon upgrade today, I too have lost all dim functions on the UPB stuff.
-Travis
I should elaborate...the events and what Alexa interprets appear to be working as HS slides the dimmer as expected. It's just that the control of the actual device does not respond. It's like the Control Use Dim no longer functions to actuate the device. On/Off commands are fine though. Everything was fine with 3.0.2.6 for me once I modified the range values to honor 0, 1-100 and 255.
-Travis
  #42
Old April 16th, 2018, 04:29 PM
Jfree23 Jfree23 is offline
Seer
Pete, great work testing X10 dimming, thanks.
I won't get to more extensive testing here for a while, but I did a few quick PCA tests on my X10 light, set to Standard in house code. As reported, on, off, work as expected. When I issue a DIM command and light is off, it turns on full, then dims. When light is already on, it dims n steps. When light is off, BRIGHTEN command seems to just turn light on full regardless of step. When light is on but at a dim level, BRIGHTEN ramps it up n steps. Not sure we will ever figure out all the combinations of switches, commands, behaviors.
Rob, another problem - did some home network work this morning, rebooted router, HS3Pi did not seem to talk to Omni any more. Log is all normal, commands seem to go out, but Omni does nothing, also does not notice event changes, does not trigger. Omni and HS3Pi both get same fixed IP address so that did not change, and I can ping Omni from HS3Pi command window. No other indications in HS3 or Omni plugin logs that things are no longer working. Happened same way after router reboot a week or so ago. Disabling/re-enabling plugin seems to fix it, but it can't seem to recover Omni connection on its own.
Edit: one more note - when I restart the plugin, I get this message in the HS3 log:
"Warning Attempt by plugin to register a duplicate link of OMNI. Plugin: OMNI Instance:"
Any idea why that might happen, or how to fix if needed?
John
  #43
Old April 16th, 2018, 06:03 PM
jchotz jchotz is offline
Seer
I updated to V28 and it did not fix the 2 problems that I have.
1 - my UPB devices that control fans & flour lites still do not turn on. They did previous to V26 and now they do not. I think this has to do with ramping them. Can you please put this back so that my lites & fans work again?
2 - still does not find any zones on my exp enc. What can I tell/show you that would help you diagnose why it continues to miss the EE zones?
Thx, Jeff.
  #44
Old April 18th, 2018, 11:25 AM
Overst Overst is offline
Seer Plus
Zone Status not working
In the latest version when a zone is bypassed the value is set to -1 instead of 1 or 3. It is also not possible to test for -1 as the value in an event (I assume because it is not a legal value).
  #45
Old April 18th, 2018, 12:15 PM
rmasonjr's Avatar
rmasonjr rmasonjr is offline
OverSeer
Quote:
Thanks - I should be able to reproduce that and get a fix...
64 Z-Wave Nodes, 162 Events, 293 Devices
  #46
Old April 18th, 2018, 12:17 PM
rmasonjr's Avatar
OverSeer
Thx, Jeff.
Roll back to the prior version until I can come up with a fix that addresses Dim/Brighten/Level
  #47
Old April 18th, 2018, 12:44 PM
drmcp drmcp is offline
Seer Plus
Quote:
i am guessing i would of had to of backup prior to upgrade in order to roll back. or is there a place to download older version of the plugin
  #48
Old April 18th, 2018, 12:55 PM
rmasonjr's Avatar
OverSeer
Quote:
You would need to restore it from a backup.
Sent from my Galaxy S7 Edge using Tapatalk
  #49
Old April 18th, 2018, 06:55 PM
Seer
I have .28 and the previous version .26 also had that behavior. How to roll back to the version prior to .26 please?
  #50
Old April 19th, 2018, 10:39 AM
rmasonjr's Avatar
OverSeer
The easiest way would be to restore from your backup. All you would need is the HSPI_OMNI.exe
  #51
Old April 19th, 2018, 10:43 AM
avpman avpman is offline
Seer Deluxe
Could you post that file here in a zip for us?
  #52
Old April 19th, 2018, 04:31 PM
Pete's Avatar
Pete Pete is offline
OverSeer
Here is one from November 2017. Looking at it in Linux I cannot tell which version it is.
Automator
HS3 Pro & Lite Edition Beta 3.0.0.4449
  #53
Old April 19th, 2018, 06:12 PM
Seer
Yeah, I'm a doofus w/o a backup so I'll just have to wait for the fix. Lesson learnt.
  #54
Old April 27th, 2018, 12:27 PM
Pete's Avatar
OverSeer
For a quickie backup of HomeSeer just:
1 - shut the HomeSeer application via Homeseer 3 GUI
2 - install WinSCP on your Wintel computer
3 - connect to your HomeSeer box via WinSCP
4 - copy the /usr/local/HomeSeer directory to say a USB stick or some place you will remember
5 - unzip the file above and using WinSCP write the file to the /usr/local/HomeSeer directory and it will replace current Omni Plugin.
6 - ssh to your box and type sudo reboot
  #55
Old April 28th, 2018, 08:59 AM
Seer Deluxe
Anyone figure out what version "the file above" is?
  #56
Old April 28th, 2018, 10:45 AM
lakemirror's Avatar
lakemirror lakemirror is offline
Seer Deluxe
Quote:
I'm assuming it's the one three posts above yours...
  #57
Old April 28th, 2018, 11:07 AM
Seer Deluxe
Quote:
All Pete says is "Here is one from November 2017. Looking at it in Linux I cannot tell which version it is. "
That doesn't identify which specific file version it is. V.24, V.25, V.27, etc
  #58
Old April 28th, 2018, 12:48 PM
lakemirror's Avatar
Seer Deluxe
Gotcha.
  #59
Old April 28th, 2018, 11:38 PM
Pete's Avatar
OverSeer
Here is V.24 and V.25
and
  #60
Old April 29th, 2018, 10:14 AM
Pete's Avatar
OverSeer
I cannot find my Omni V.26 or V.27 updates because none of the zip files when updating are being saved anymore in the most current builds of Homeseer 3.
I only backed up the Homeseer directory when upgrading versions of Homeseer.
Checking old Omni updater txt files update downloads the old dropbox links / files do not exist anymore from November-December 2017.
Closed Thread
HTML code is On
OMNI Plugin v3.0.2.6 rmasonjr HAI/OMNI Panel for HS3 Plug-in (rmasonjr) 46 April 10th, 2018 10:11 AM
OMNI Plugin v3.0.2.3 rmasonjr HAI/OMNI Panel for HS3 Plug-in (rmasonjr) 10 September 26th, 2017 11:26 AM
OMNI Plugin v3.0.2.2 rmasonjr HAI/OMNI Panel for HS3 Plug-in (rmasonjr) 22 September 11th, 2017 12:10 PM
Events using HAI plugin not working with OMNI plugin lakemirror HAI/OMNI Panel for HS3 Plug-in (rmasonjr) 7 August 15th, 2017 04:59 PM
Using the Omni plugin rod_tucker HAI/OnQ Panel (HS2) 4 September 2nd, 2003 01:04 PM
