Danfoss Living connect thermostat - No longer available in Z-Wave
    Hi all.
    I am trying to install a Danfoss Living connect thermostat in to homeseer but i cant get it to update homeseer.
    info on the device can be found here: http://www.pepper1.net/zwavedb/device/6
    i also get the following error in the log
    09/05/2011 22:34:59 Z-Wave Warning !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! 09/05/2011 22:34:59 Z-Wave Warning The climate control schedule command class is not fully supported for the device at node 18. Please contact HomeSeer Technologies. 09/05/2011 22:34:59 Z-Wave Warning !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Then i get the following error
    09/05/2011 22:44:23 Warning Aborting Z-Wave send, taking too long to send command to node 18 waited 2 seconds
    09/05/2011 22:44:21 Warning Sensor woke up, but queued configuration command encountered an error when sent. Type=ASSOCIATION_SET_HOMESEER, Result=Association Failed - Z-Wave Z-Wave Interface Z-Wave Thermostat 18 does not support Associations.
    can anyone help me with this one?
    Greig.
    Scripts =
    Various
    I want to use the danfoss thermostast too...
    Any answer from the Homeseer-Team???
      Have the same problems
      Hi all,
      Homeseer team, please give some help:
      We all seems to have the sames problems with LIVING CONNECT THERMOSTAT from DANFOSS.
      (I also still have problems with the HRT4-ZW & HRT4 ASR-ZW from HORSTMANN)
      Thank you,
        Originally posted by sebastienronsmans View Post
        Hi all,
        Thank you,
        I just want to say thankyou both for your support and I hope we may get an answer from homeseer soon.
        Greig.
        Scripts =
        Various
          I'm also having same probleem with the Danfoss living Connect
          Found out that the in the device setting you can set the number of degrees when setting off.
          Also installed the zwave thermostaat in Homeser this will detect the device but will show a error
            @Chak:
            You are probably referring to the new Danfoss Living Connect radiator valve. I was hoping it would respond to the generic Zwave thermostat plugin, but reportedly it doesn't.
            I sure hope this can be solved. Homeseer people? Please?
            Regards!
            Erwin
              You guys need to contact the manufacture of this hardware and have them contact HomeSeer.
                With all my respect to HST, Rupp.
                Are you serios about it? Maybe in the USA it is ordinary case when "End Users" starting negotiation process between Ford and Magna companys. But here in Europe "End User" awaiting qualified support. Something like this: "Sorry sir, of course we will fix the compatibility problem (to the Z-Wave CERTIFIED product) in short time". Or I am wrong?
                  I agree.
                  But nevertheless I've sent an e-mail to Danfoss, but very much doubt that this would make any difference. Manufacturers should be in contact to resolve this.
                  Also, wasn't it the same case with the previous Danfoss valve? (setback mechanism) A Homeseer update made it work. So, HS people, you probably have your contacts at Danfoss. Please?
                  Regards!
                  Erwin
                    Just let the manufacture know you need their hardware to work with HomeSeer.
                      While I no longer use any Zwave I have a question. After seeing how HomeSeer has to jump through hoops to make things work for one device and then another as well as for each manufacturer it makes me wonder. Is there no set standard that Zwave manufactures must adhere to? That seems to be the case and I wonder if that does not hurt the protocol overall and limit it over the long haul?
                      Marty
                        Rupp, we both knows that Z-Wave dev. team from Danfoss Randall (http://danfoss-randall.co.uk/default.html) will not talk with HST anymore. So your advice are helpless.
                        Maybe you just asking about help from guys who have knowlege about Danfoss and Horstmann products: http://en.z-wave.me/content/consultancy
                        It is not so difficult to ask about help.....
                          Post on the z-wave.me site:
                          We are working on it right now!
                          Current version of Z-Cloud does not support Danfoss Living Connect Thermostats in a user friendly way. You can use them in expert mode only and that's not what you want.
                          But we are working on this and we hope to be able to update Z-Cloud with thermostat support about 31 May. We will make an announcement in the official forum topic to let you know about this important update.
                          Any news from Homeseer? ;-)
                            any news on whats going on with this???
                            Greig
                            Scripts =
                            Various
                              Just came off the phone with a Z-wave expert from Danfoss in NL.
                              He told me this: The Living Connect lineup uses a proprietary language within the Z-wave protocol that allows the various components to communicate, EXCEPT for the Living Connect radiator valve. The radiator valve uses BOTH the proprietary Living Connect language AND generic Z-wave.
                              According to him, pairing the radiator valve with non-Danfoss controllers should work. There's no hope for the rest of the components though. Pity, they have a very nice room temperature sensor and floor heating components. :-(
                              Wouldn't it be great when HST could look into this. Maybe they could get Danfoss to send them a sample? ;-)
                              Erwin
