Excuse me for being dense if that is the case, but I am just now getting around to using this plugin and HS3 (have registered your plugin).
I am trying to figure out how to do the following: I have a 5 button wall mount master controller that I have sent an LED command to that enables me to trigger events now. The issue is when I try to create an event that sets the LED status based on the button's value where I get into trouble.
The goal is press the button, fire an event, turn a device on and set the LED to on. Press the same button, turn a device off, set the LED off. Can you explain how this would be done using your plugin?
I have been working on this for awhile, but I'm sure the moment I post this I'll figure it out...seems to always happen that way...lol. But just in case, would you mind lending me a clue?
P.S. It seems like the answer may be to have an event generated based on a MBP instead of a value change.
