KMS Remote Restart
    KMS Remote Restart
    Spud,
    If the sequence is:
    - HS3 is up and running
    - Remote PC is booted up
    - HSPI_KMS.exe is executed
    everything is fine.
    Once HS3 is restarted the Remote PC does not auto reconnect.
    I have the remote PC setup with the following command:
    C:\Drivers\KMS\HSPI_KMS.exe server=192.168.0.179 instance=MaryAnnLaptop console=false autoreconnect=300
    Error I get in the log after the HS3 reboots every 5 minutes (aka autoreconnect=300) is:
    Nov-09 16:19:02 Error Initializing plug-in(2): KMS Instance:MaryAnnLaptop:Object reference not set to an instance of an object.STACK: at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()
    In order to make the error go away I have to reboot the Remote PC.
    Do I misunderstand the auto-reconnect option?
    Ken J.
    I will have a look today and let you know.
      Problem fixed in version 3.0.0.3 available here
        That seems to have corrected it...thanks.
        Ken J.
