So, I updated all of my plugins from Blade (BLBackup, BLRfid, BLRadar, BLDenon) and as usual, needed to restart HS3Pro (3.0.0.398, Windows 10) for them to take. At startup, I got the following:
6/7/2018 5:37:04 AM ~!~Error~!~Initializing plug-in(2): BLDenon Instance::Object reference not set to an instance of an object.STACK:Server stack trace: Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()Startup Complete, 1 errors detected, check the log for more information.
So, I decided to shut down HS3 and restart it. I did not get the BLDenon error, but I did get the following:
6/7/2018 5:46:05 AM ~!~Error~!~Initializing plug-in(2): BLRadar Instance::Object reference not set to an instance of an object.STACK:Server stack trace: Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()
So, something is amiss with these updates.
Elliott
Elliott
