ECM data shows in HS log not Monitor
    Using trial v1.0.11.0 w/ HS v2.5.0.44. ECM data is showing up in the HS log when enabled but not in Reports. Using two ecm-1240's. Seems like an ecm serial number match thing, but I'm pasting from the ECM Engine software.
    Bob
    You are using the Forward Data... Home Automation Plugin option in the Engine, correct?
    You need to use the TCP/IP server part. I use port 7080, enable it and use ASCII, the click Listen.
    In the plugin, enter the IP of the machine running the Engine and use 7080 as the port.
    I am using 2.23 of the Engine
    Make sure you add the monitors to the plugin and specify the correct serial number. Then make sure the database logging is enabled in the options of the plugin.
    That should do it.
    Cheers,
    Bob
      Fixed - Was using wrong setup
