Mark,
I have installed several First alert detectors with the Insteon Smoke Bridge. The setup went fine and your plugin communicates with the smoke bridge. I created an event to speak when I test the detectors. The trigger is "When test is detected" Then: Speak "Testing"
When I test the detectors, the LED on the smoke Bridge Flashes RED, but nothing in the HS3 Log, and the event doesnt run. Am I missing something?
Do I need to setup the smoke bridge in some way?
The advanced configuration shows Status 100=ON
System is HS3 3.0.0.152, Win7
PI is newest 3.0.5.16
