Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Blade Plug-Ins > BLLAN (3P)
BLLAN (3P) Discussion of BLLAN plug-in
Old July 8th, 2016, 03:19 AM
mikee123 mikee123 is offline
Ping settings question
I am using this plugin to ping my 2 phones, and when they are online they trigger a event to switch a virtual switch to home.
Ideally I want this to go 'online' as quick as possible after connecting as that virtual switch turning from away to home triggers other things too. On the other hand I do not want to have hundreds of unnecessary actions, looking at my log I can see a lot of 'traffic' which I can probably reduce
Jul-08 05:55:24 BLLAN Info Computer - Virtual Switches Mike S6 is connected (Downtime: 12 secs) Jul-08 05:55:11 BLLAN Info Computer - Virtual Switches Mike S6 is not connected (Uptime: 27 secs) Jul-08 05:55:11 BLLAN Info Computer - Virtual Switches Mike S6 --- 1 PING failure Jul-08 05:54:44 BLLAN Info Computer - Virtual Switches Mike S6 is connected (Downtime: 12 secs) Jul-08 05:54:31 BLLAN Info Computer - Virtual Switches Mike S6 is not connected (Uptime: 14 secs) Jul-08 05:54:31 BLLAN Info Computer - Virtual Switches Mike S6 --- 1 PING failure
I have set ping failures to 1, and ping interval to 10 seconds.
What would a good setting be ?
Manually reset your Zee's network settings - Question DESIi1 HomeTroller Zee 1 July 29th, 2015 08:16 PM
Device settings question rex2802 Lighting & Primary Technology Discussion 1 December 9th, 2008 09:09 AM
Question: HS Links - linksedit.asp - settings.ini alevey HomeSeer General Discussion Area 13 December 17th, 2004 02:17 PM
hs.ping carletondm Programming with HomeSeer 5 June 6th, 2002 10:32 AM
Can you use hs.ping to ping names taffy Script & Plug-In Development 5 March 30th, 2002 09:06 PM
