Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Blade Plug-Ins > BLLAN (3P)
BLLAN (3P) Discussion of BLLAN plug-in
Old November 29th, 2016, 08:14 PM
garciacg garciacg is offline
BLLAN High CPU Utilizatoin
Hi Bob, I followed a thread on this topic a year or so ago but noted that it hadn't come to conclusion. I too have been noticing high CPU utilization from HSPI_BLLAN.exe on one of my two HS3 machines. Both machines are physically identical (Asus EeeBox w/Atom N270 CPU - 2GB Memory & 60GB SSD). Both running WinXP SP3 with the same drivers. For purposes of this, I'll refer to them as System 1 and System 2.
System 1: Running only HS3
Current Date/Time: 11/29/2016 3:09:28 PM
HomeSeer Version: HS3 Pro Edition 3.0.0.297
Operating System: Microsoft Windows XP Professional - Work Station
System Uptime: 0 Days 0 Hours 14 Minutes 54 Seconds
IP Address: www.xxx.yyy.zzz
Number of Devices: 260
Number of Events: 91
Available Threads: 200
Enabled Plug-Ins
2.0.5.0: BLGarbage
2.0.35.0: BLLAN
2.0.123.0: BLRadar
3.0.1.18: HAI
3.0.0.68: HSTouch Server
30.0.0.33: RFXCOM
3.1.4.9: SqueezeBox
3.0.0.35: UPBSpud
3.0.0.36: X10
3.0.1.87: Z-Wave
System 2: Running HS3 and HS2 v2.5.0.81 simultaneously
Current Date/Time: 11/29/2016 4:12:57 PM
System Uptime: 8 Days 15 Hours 43 Minutes 22 Seconds
IP Address: 192.168.1.99
Number of Devices: 42
Number of Events: 16
Enabled Plug-Ins
2.0.5.0: BLGarbage
2.0.35.0: BLLAN
3.0.0.75: HSTouch Server
3.0.1.87: Z-Wave
Both systems have 1 computer device configured in BLLAN, localhost @ 127.0.0.1, so as to make the ping time as short as possible. 10 second ping intervals.
BLLAN on System 1 consumes 20-25% CPU during each ping, however, System 2 is negligible. I incrementally disabled plugins on System 1 to see if there was some other interaction, but it made no difference. Attached are screenshots from Sysinternals Process Explorer with the HSPI_BLLAN.exe process singled out. You can see the CPU spike on System 1 at 10 second intervals. There is also a considerable difference in I/O activity on System 1 vs. System 2.
That said, I was wondering if there is anything that jumps out at you that might explain this? Thanks in advance...
Craig
HTS6 on Windows 10. HS3 Pro 3.0.0.425, Z-NETv1 1.0.22, BLGarbage 2.0.5.0, RFXCOM 30.0.0.36, OMNI 3.0.2.8, Z-Wave 3.0.1.190, Squeezebox 3.1.4.15, MCSSprinklers Pro 2.18.0.7, BLRadar 2.0.126.0, UPBSpud 3.0.0.43, X10 3.0.0.40, JowiHue 2.0.2.2
Old December 17th, 2017, 08:42 PM
apluck apluck is offline
Hi, did you find any solution to this? I am seeing high CPU from BLLAN as well every 10 seconds while it pings.
Old December 18th, 2017, 07:57 AM
Blade's Avatar
Blade Blade is offline
I will have to look into this one - can you log a ticket for this on my help desk
Cheers,
Bob
BLLAN and events. 519zwave BLLAN (3P) 1 June 28th, 2015 01:43 AM
Does BLLan verify MAC address? mrceolla BLLAN (3P) 5 May 15th, 2015 08:22 AM
BLLAN not In Updater sonypoolplr BLLAN (3P) 4 June 4th, 2014 01:34 PM
BLControl now interfaces with BLLAN Blade BLControl (3P) 0 March 5th, 2014 01:06 PM
Help with BLLAN jrjmpls7 BLLAN (3P) 0 September 11th, 2013 02:32 PM
