Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Blade Plug-Ins > BLLAN (3P)
BLLAN (3P) Discussion of BLLAN plug-in
Old January 26th, 2018, 11:05 AM
jrjmpls7 jrjmpls7 is offline
Help
I'm have BLLAN set up to monitor several cameras which go off-line periodically. I have events set up to recycle the power to get them back on-line. But using the value of the BLLAN device going to 0 never triggers the corresponding event. Am I missing something? Shouldn't the change in the BLLAN device be able to trigger events just like any other device?
Thanx
Old January 26th, 2018, 01:02 PM
519zwave's Avatar
519zwave 519zwave is offline
I can't specifically help you here. But I have noticed that your subject lines don't reference your issues. I'd suggest adding a bit in there so we can see at a glance your issues.
Jim
Plugins:Z Wave 3.0.1.55, HS3 Pro 3.0.0.208, HS3Touch, HS3Touch IOS, Z-Net, SceneMaster, XBMC, Sonos, Media Controller, Envisalink (52 Virtual nodes), JowiHue, EasyTrigger, Liftmaster MyQ, BLBackup, BLLAN, BLRadar, Pushover
Devices:Cooper RF9540, Cooper Scene, Yale Locks, Sonos, Phillips Hue and Lux, DSC, Somfy Blinds
Old January 26th, 2018, 01:54 PM
Blade's Avatar
Blade Blade is offline
I will take a look at the code
Cheers,
Bob
Old January 26th, 2018, 03:54 PM
Blade's Avatar
The device should change to 0 for Off and 100 for On
Old January 26th, 2018, 04:02 PM
Kerat Kerat is offline
Please confirm, to determine if the cams are online or offline you are using BLLAN to ping the device?
Old January 26th, 2018, 07:22 PM
yes. Using BLLAN to ping the cams. After several failures, the BLLAN value changes to 0. Have several events set up to run when a BLLAN device changes to 0. But none of the events ever trigger
Old January 26th, 2018, 10:19 PM
Blade's Avatar
Post a screenshot of your event
Old January 27th, 2018, 12:24 AM
Yea, screenshots of your event would help. Try setting the trigger to “a device changes and becomes” instead of “a device has a value of”
Old January 27th, 2018, 04:24 PM
Here's a screenshot. 21-Camera Basement CrittersCam1 (and 2) is a BLLAN device and 22-Camera Basement CritterCams Power is an appliance on/off module supplying power to the two cams.
Old February 16th, 2018, 11:14 AM
Does anyone have an idea how I can fix?
Thanx
Old February 16th, 2018, 11:51 AM
wadesready wadesready is offline
Thanx
if you are running blue iris and plug in it is an easy fix... when the camera has no signal toggle a switch and it restarts. I have one that is a problem, and I set it up as above. the camera probably needs to be replaced, but I will wait until it is totally gone...
Old February 16th, 2018, 01:49 PM
Did you read my posts? I know that cycling the power fixes it. The problem is that when BLLAN see s the cam offline it never triggers the event to cycle the power.
Old May 26th, 2018, 01:01 PM
COMaQ13TxSG's Avatar
COMaQ13TxSG COMaQ13TxSG is offline
Viewer
I have had trouble with 'Or if' statements in events.
Have you tried removing the 'or if' and using one cam per event to fail and trigger the switch?
