Knowledge Base
This is a sticky topic.
    Knowledge Base
    Here is the link to my web site where previous posts exist for this plug-in.
    You can look through old posts HERE
    If anyone has any tips or tricks or past knowledge experiences please post them here in this thread.
    Cheers,
    Bob
    What receivers are supported
    Your list on the Blade forum is not accessible please provide the list here
      Not a user myself but I believe the answer is:
      Denon AVR 4306
      However, it might be worth trying on others.. you never know till you try
      TrOjAn
        That's correct, Bob originally wrote the plug-in based off the AVR-4306 network command set. I've used it for several years. It should fuction for most of the standard features in other models unless they've changed the command set. If you try it and it works, please post the model you are using.
          Denon RCD-N7
          Does the plugin support Denon RCD-N7?
            I have a Denon X4000 - Has anyone tried it on the 4000?
              Anyone know how to use the IR codes for the new AVRs? I would attach it but the HomeSeer police limit attachments to a MERE 390k... HAHAH
              Here is the link to the file from Denon:
              https://usa.denon.com/us/product/hom...vers/avrx8500h
              Scroll all the way down and DL the "IR_Code_V01 document...
              Transitioning to HS3Pro .298 - WinXPEmbedded
              Hometroller S3 Pro - WinXPEmbedded - HSP 2.5.0.81 - BLStat - HSPhone - HSTouch Srvr 1.0.0.73 - Touchpad - BLLan - BLOccupied - DSC Plug 2.0.0.14 - BLStat .38
                This link does not work, I get:
                PHP Warning: mysql_connect(): Client does not support authentication protocol requested by server; consider upgrading MySQL client in F:\BladeWebSite\wwwroot\BladePluginsWebSite\phpbb2\db\mysql4 .php on line 48 PHP Warning: mysql_error(): supplied argument is not a valid MySQL-Link resource in F:\BladeWebSite\wwwroot\BladePluginsWebSite\phpbb2\db\mysql4 .php on line 330 PHP Warning: mysql_errno(): supplied argument is not a valid MySQL-Link resource in F:\BladeWebSite\wwwroot\BladePluginsWebSite\phpbb2\db\mysql4 .php on line 331
