I have an event that turns on a set of lights. It is controlled triggered from an simple Insteon switch or from a voice command. That works well.
At the door to the room I have also a Keypad Linc V2 Dimmer. It has the main load button at the top for ON and a big button at the bottom for the OFF as well as 4 other buttons with lights.
I would like to also control the event with the main LOAD ON and OFF from the KeypadLinc.
So if I use a voice command to trigger the event I also send a control device to turn on the KeypadLinc.
BUT what happens is the event sees the KeypadLinc turning on so the event fires again. I need a way to turn on the Keypad without triggering any event until the current event is completed. Otherwise it goes off and on and off and on repeatedly.
Hope that is clear?
Hope that is clear?
