I've had this problem for quite some time but didn't miss it much before now. Can someone please help in the right direction?
I'm using build 2.0.2057. The problem has been there for a long time, i believe it came after upgrading from build 2.0.2014.
Her is the error (some in Norwegian):
Sporing av samlingslasting:=== Pre-bind state information ===
LOG: DisplayName = Scheduler, Version=2.0.1951.4, Culture=neutral, PublicKeyToken=124b309a6c508145 (Fully-specified)
LOG: Appbase = C:\Programfiler\HomeSeer 2LOG: Initial PrivatePath = html\updater\\binCalling assembly : updater, Version=2.0.1951.4, Culture=neutral, PublicKeyToken=null.
LOG: Publisher policy file is not found.
LOG: Host configuration file not found.
LOG: Using machine configuration file from C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\config\machine. config.
LOG: Post-policy reference: Scheduler, Version=2.0.1951.4, Culture=neutral, PublicKeyToken=124b309a6c508145
LOG: Attempting download of new URL file:///C:/Programfiler/HomeSeer 2/Scheduler.DLL.
WRN: Comparing the assembly name resulted in the mismatch: Revision Number
Stakksporing:
[FileLoadException: Samlingens manifestdefinisjon med navnet Scheduler tilsvarer ikke samlingsreferansen.] updater.WebForm1.Page_Load(Object sender, EventArgs e) +0 System.Web.UI.Control.OnLoad(EventArgs e) +55 System.Web.UI.Control.LoadRecursive() +27 System.Web.UI.Page.ProcessRequestMain() +731
Versjonsinformasjon: Microsoft .NET Framework versjon:1.1.4322.573; ASP.NET versjon:1.1.4322.573
Dag-Inge
Stakksporing:
Dag-Inge
