vb script runs locally but not in event
    Ok so I was going to put this in my setting up email thread but this is a different issue now..
    Ok so here is the deal... I subbed all the email addys out....
    drop this in notepad and call it say email.vbs
    set msg = WScript.CreateObject("CDO.Message")
    msg.From = "MyServer@MyDomain.org"
    msg.To = "Thanks@comcast.net"
    msg.Subject = "Security Alert"
    msg.TextBody = "Alarm Tripped - expect call from ADT"
    msg.Configuration.Fields("http://schemas.microsoft.com/cdo/configuration/smtpserver") = "smtp.comcast.net"
    msg.Configuration.Fields("http://schemas.microsoft.com/cdo/configuration/sendusing") = 2
    msg.Configuration.Fields.Update
    msg.Send
    simple and easy
    now run this locally and it works.. sends an email from my machine through comcast.net as a smtp server...
    all is good..
    however here is my issue..
    rename file to email.vb and drop in scripts folder
    create a event to run manually and reference this script.
    I get an error like I was in my previous topic...
    11/15/2007 1:06:12 PM Error Script compile error: Syntax error.on line 14
    I dont have 14 lines of code but I am noticing HS is compiling to do the script and erroring out... here is what the log also says...
    11/15/2007 1:06:12 PM SCR Option Strict Offimports Schedulerimports SystemPublic Module scriptcode8#Region "Automatically generated code, do not modify"'Automatically generated code, do not modify'Event Sources Begin Public WithEvents hs As Scheduler.hsapplication Public WithEvents hsp As scheduler.hsp Public WithEvents hssystem As scheduler.phone0'Event Sources End'End of automatically generated code#End Regionset msg = WScript.CreateObject("CDO.Message")msg.From = "Homeseer@RiggsClan.dyndns.org"msg.To = "JeffreyJRiggs@comcast.net"msg.Subject = "RiggsClan Security Alert"msg.TextBody = "Alarm Tripped - expect call from ADT"msg.Configuration.Fields("http://schemas.microsoft.com/cdo/configuration/smtpserver") = "smtp.comcast.net"msg.Configuration.Fields("http://schemas.microsoft.com/cdo/configuration/sendusing") = 2msg.Configuration.Fields.Updatemsg.SendEnd Module
    Ok so this runs on my XP machine..
    but HS is installed on a server 2003 box...
    just tried running the .vbs file on server 2003 and get an error on line 9 which is the
    msg.send
    so I wonder what is different between the two!!!!
    rest of the error is
    The message could not be sent to the SMTP server. The transport error code was 0x80040217. The server response was not available
      CDO is a CDONTS object that comes with Active Server Pages. Your Win2K3 box probably doesn't have asp installed.
        I have asp installed and allowed in iis
        any other ideas?
        appreciate it...
        Jeff
          guess another question then is can I have HS
          1. fire off an event...based off of alarm trip (I know you can do this)
          2. Runs vbs file on my xp machine
            Ok I tried something..
            I created a .asp file (found one on the web)
            opened it with IE on my server 2003 server. File is on my desktop.. all that was shown in IE was the code
            dropped that file in my wwwroot folder and in IE now it shows up as a web form asp file...
            so here is a question... could it be that HS needs to be setup in iis as a website?
            I tried but it couldnt start it and I think that is because HS is controlling it as a website.....
            I have port 80 for my website and port 81 for HS
            there has to be something to do.....
              Do you have SNTP installed?
                I do have smtp installed.. however uninstalling now.... same as pop3 mail
                trying that as I dont need it and didnt realize it was installed.... then I saw your message...
                  well I guess this is the crappy way to do it... but how I will have to ...
                  put vb on the xp machine
                  setup a scheduled task
                  have HS run the scheduled task on the XP machine..
                  sucks but I dont know how else to run it....
                    well this was weird... seems server 2003 talking to comcast I had to add my user name and password sections of the cdo.message part and now server 2003 can send the emails...
                    HS still gives me errors so I found a different work around...
                    I didnt do it yet but I can...
                    run the vbs within HS to create a vbs with my data then run it..
                    what I mean is HS will run the vbs as a program but not as a script.. so have it run a static file to create a vbs that has my values then run that new file and I will get an email..
                    that is a crappy way to do it but it would work... I guess
