I am using an HS_ListBox control to display the Devices Selector. There are always devices I can't display using the slider associated with the listbox.
I believe the problem is that the maxrows property is set automatically in the control based on the control size and font size, but the second devices screen (Location 2) displays two lines for each device. There is a line for the device name and a line for it's status (on/off).
The control thinks it has 12 lines to display, but really has 24. The slider won't scroll down because there are only 12 lines to display, but I can only see some of the devices.
I tried this on a windows client and a CE client with the same results using a 240x294 graphic window. The project "Standard 800x480" has the same result. I select a location with 10 insteon devices. The slider starts at the bottom. I can't display all of the devices.
Is there a way to manually adjust the maxrows property or is this a bug fix?
