Is it possible to adjust the FM tuner frequency?
Tuner Frequency Adjustment
Originally posted by Ramymounir View Postwhy are most of the posts here unanswered?
Cheers
AlHS 4.2.8.0: 2134 Devices 1252 Events
Yes you can set the frequentie directly, or set your tuner to a defined preset.
The code for setting the preset is:
actionset= "TPANB2" 'This set radio tuner to preset B2
reply = hs.PluginFunction("BLDenon","","SendRawCommand", actionset) 'Response is current frequentie
I use a script which i call with HStouch which passes the selected value of a listbox to this script. Offcourse this is not the complete script but you could work with this.
As im now using the Denon for video i cannot give you the code for frequentie setting but that is documented in the rs232 document of Denon.
edit: if you google for AVR-3808CISerialProtocol_Ver5.2.0a".pdf" you should be able to find it.
Other than some volume sliders on HSTouch, I find myself using SendRawCommand nearly all the time. I find that it is definitely worth learning the "Denon serial protocol" to control speaker configurations, surround modes and etc -- everything beyond simple power, volume, and source selection.
