Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > Z-Seer+
Z-Seer+ Discussions about Z-Seer+ Z-Wave Network Diagnostics Software
  #181
Old November 21st, 2017, 04:59 AM
tzachb tzachb is offline
Zseer + no routing arrows
Hello everyone
i am having an issue with Zseer+ , it does not showing the routing information on the screen.
i am using the latest Aeon Stick Gen 5 on HS3 pro version latest 3.0.383.
i am running zseer.exe from hs3 directory as this is the only way it load fine and connect to my zwave network.
net framework 4.52 is installed on my windows 7 successfully. all requirements as needed but no info is showing . i cant see routing .(no arrows)
please advise as i am out of ideas . attached screen shot file of my zseer+.
thanks
Tzach
  #182
Old November 21st, 2017, 10:28 AM
cowinger cowinger is offline
You can right click on the device in question and select "Show Command Route".
  #183
Old November 22nd, 2017, 04:43 AM
Thanks, i already tried that but i don't see any routes arrows.
whats strange is that if i look on the zwave node info screen on hs3 i can the last working route information but it does not reflect to zseer software ?
whats else can i try ? i almost give hope on this .
if someone has any advise ill be happy to try anything .
thank you all.
Tzach
  #184
Old November 25th, 2017, 11:55 AM
Update:
FYI , after recreating almost all the nodes, routes arrows started to appear in Zseer+ software .
Tzach
  #185
Old December 1st, 2017, 10:38 PM
TeleFragger's Avatar
TeleFragger TeleFragger is offline
Originally Posted by Rupp View Post
You should be able to use your HS3 license code.
Really? I didn't know that and ended up choosing the upgrade from HS2 Z-seer!!!!!
New Z-Seer+ For HS3 macromark Z-Seer+ 12 September 6th, 2017 05:02 PM
