Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > Z-Seer+
Z-Seer+ Discussions about Z-Seer+ Z-Wave Network Diagnostics Software
  #141
Old June 11th, 2017, 05:30 PM
bebaldin bebaldin is offline
I just installed .28 but I still see the same issue of the program hanging for long periods of time attempting to get neighbor info. It could be the device itself - a Schlage deadbolt lock - but I can communicate just fine with the device itself.
If I try to do a test all every single device fails to communicate in Z-Seer, but I can still communicate with every one in the Z-Wave controller page for each network.
  #142
Old June 11th, 2017, 06:51 PM
integlikewhoa integlikewhoa is offline
Do you have more then one z-wave network? Did you read the past posts?
  #143
Old June 16th, 2017, 04:14 PM
macromark's Avatar
macromark macromark is offline
HomeSeer Technologies
Circles Z-Seer 3.0.0.40 Now Available!
The new build has just been released. Just launch Z-Seer and the update should be detected automatically. You'll also need to install Z-Wave plug-in v3.0.1.130
New improvements:
  • Support for multiple Z-Wave interfaces
  • Set command route function
  • Set response routes function
  • Updated docs
  #144
Old June 16th, 2017, 04:29 PM
enigmatheatre's Avatar
enigmatheatre enigmatheatre is offline
Super Seer
Originally Posted by enigmatheatre View Post
I have the same issue and I have a UZB: "Cannot access HomeSeer: Object reference not set to an instance of an object."
Greig.
Same problem with 3.0.0.40.
I believe Rich was working on this. Is there a fix?
Greig.
Zwave = Z-Stick, 3xHSM100™ 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts =
Various
  #145
Old June 16th, 2017, 04:34 PM
rjh's Avatar
rjh rjh is offline
Copy the zseer exe file to your HomeSeer folder and run it from there. Does that work ok?
Greig.
  #146
Old June 16th, 2017, 04:45 PM
I had the same problem with the new version but that was fixed after I move the .exe file to the HS3 root folder. Something needs to be done to fix this.
Scrolling works great now.
Next to test on multi controller setup.
  #147
Old June 16th, 2017, 04:47 PM
donstephens's Avatar
donstephens donstephens is online now
Z-Wave Thermostats
I have two networks, both of which do not show thermostats, although they are shown in the log as per image. Is there something special about these devices?
Don
  #148
Old June 16th, 2017, 05:04 PM
I have thermostats (zoned system) and all mine show up without and issue.
  #149
Old June 16th, 2017, 05:41 PM
Super Seer
Yep that works for now but I would prefer to not have to remote in to my system to run this as I would like to run it on my laptop.
Greig.
Scripts =
Various
  #150
Old June 16th, 2017, 06:06 PM
rjh's Avatar
rjh rjh is offline
Did try the reformat command, maybe they are hidden on the screen. I don't see a reason they are not displayed.
  #151
Old June 16th, 2017, 06:11 PM
Reformat did it.
Thanks.
Don
  #152
Old June 16th, 2017, 08:20 PM
Bob_Linux_User's Avatar
Bob_Linux_User Bob_Linux_User is offline
I am not sure if I did something wrong or what. I rearranged my node display and saved the layout. After the save, the bottom section of the zseer + display is no longer displayed. Just the node boxes appear. I was able to get the info section back by deleting the config file in the user/appdata/local/.... folder. I could not find any other solution.
Bob
  #153
Old June 16th, 2017, 11:01 PM
Richel Richel is offline
Crashed HS3
Originally Posted by macromark View Post
The new build has just been released. Just launch Z-Seer and the update should be detected automatically. You'll also need to install Z-Wave plug-in v3.0.1.130...
I installed this Z-wave plugin. It installed unsuccessfully. Now my HS3 Pro is totally crashed. When I restarted the program I get the error message "Error~!~GetConnection error Unable to load DLL 'SQLite.Interop.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)"
The frustrating thing as I have gone to a back up of my HS3 program and I still get this error. Any help would be appreciated.
Elliott
  #154
Old June 17th, 2017, 12:10 AM
This is just a guess but . . .
Take a look in the 'Bin' folder and see what version of SQLite.Interop.dll you have.
Mine is 1.0.87.0
Perhaps it was corrupted with the new Z-Wave load.
Hope this is of some help.
Don
  #155
Old June 17th, 2017, 12:11 AM
Elliott
Chances are that the plug-in files and the DLLs are mismatched, possibly due to a bad installation, or the named DLL is simply missing. You may need to download the new plug-in manually, and then copy the HSPI_Zwave files to Homeseer, and the DLLs to Homeseer\bin\Z-Wave as appropriate.
I am assuming you are on Windows - I don't think Linux uses SQLite.Interop.dll but I am not certain of that.
Stop the plug-in, manually copy the files from the ZIP of the plug-in as appropriate, and then restart it.
  #156
Old June 17th, 2017, 12:30 AM
New improvements:
  • Updated docs
Just did the upgrade to .130 and installed the new Z-Seer. This works GREAT so far. Was able to scan two of my four networks (so far) and clean up some routing issues with the full optimize. Layout save and open works fine. I can switch between networks effortlessly.
Need to do some more testing on my larger two networks, but so far results have been excellent. Thank you!
  #157
Old June 17th, 2017, 04:11 AM
Moskus's Avatar
Moskus Moskus is offline
Agreed!
HSPro 3.0.0.435, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
  #158
Old June 17th, 2017, 07:24 AM
Chances are that the plug-in files and the DLLs are mismatched, possibly due to a bad installation, or the named DLL is simply missing. You may need to download the new plug-in manually, and then copy the HSPI_Zwave files to Homeseer, and the DLLs to Homeseer\bin\Z-Wave as appropriate. ...
Thanks all. I got it working again by using the HS3 installer (.msi) to install a new installation. I then copied over from my backup, certain of my files. However, I have had to install one-by-one all my plugins. Lots of hours of work troubleshooting and re-installing.
Elliott
  #159
Old June 17th, 2017, 01:25 PM
Duomi8 Duomi8 is offline
Error when upgrading
I purchased this around a week ago and also had to upgrade the Z-wave plug in. Now after upgrading Z-Seer+ it says 'Z-Wave plugin in either not loaded or is not the correct version, version 3.0.129 or later is required.
The current version of the the Z-wave plugin is 3.0.1.124. When attempting to update, when display the 'additional interfaces' the following error is displayed :
Please wait for the updater control file failed to be downloaded or parsed
A similar message displayed previously when originally installing Z-seer+, and had to pull down latest version of HomeSeer vs '3.0.0.318 (Linux)'.
Any ideas ?
  #160
Old June 17th, 2017, 01:27 PM
Any ideas ?
New improvements:
  • Updated docs
Version 130 is in the beta section and like was already posted you need to use that one.
New Z-Seer+ For HS3 macromark Z-Seer+ 12 September 6th, 2017 05:02 PM
