Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > Z-Seer+
Z-Seer+ Discussions about Z-Seer+ Z-Wave Network Diagnostics Software
  #161
Old June 17th, 2017, 01:42 PM
Duomi8 Duomi8 is offline
There are so many posts, can you kindly provide a link to this or the post that has the link.
I think you mean a beta version of the Z-wave plugin, and that then it is still possible to update to it even after not being able to see the list of plugins due to the error.
However correct me if I am mistaken.
  #162
Old June 17th, 2017, 01:45 PM
integlikewhoa integlikewhoa is offline
Yes the plugin. Can you post a screen shot of the updater.
  #163
Old June 18th, 2017, 12:31 PM
Jackpost Jackpost is offline
Is there a way to adjust font size, the device info is not usable...
  #164
Old June 19th, 2017, 03:12 PM
The Profit's Avatar
The Profit The Profit is online now
Originally Posted by macromark View Post
The new build has just been released. Just launch Z-Seer and the update should be detected automatically. You'll also need to install Z-Wave plug-in v3.0.1.130
New improvements:
  • Support for multiple Z-Wave interfaces
  • Set command route function
  • Set response routes function
  • Updated docs
Hello Mark, I am using the only link that I've found in this thread for the install docs and they mention that Z-Seer+ will only connect to one z-net at a time and that the others need to be shut down. Is this still the case with the update for multiple z-net's?
Here is the help link that I'm using: http://help.homeseer.com/help/z-seer/static
Is there a new link for the updated version?
Thank you
HS3 3.0.0.420 & HSTouch 3.0.55 with 700 Devices, 358 Events
Plugin's:
BLBackup, BLOccupied, BLShutdown, EasyTrigger, Ecobee,
weatherXML, Jon00 Alexa Helper, Network Monitor, Z-Wave 3.0.1.200
  #165
Old June 19th, 2017, 03:29 PM
macromark's Avatar
macromark macromark is offline
HomeSeer Technologies
Thank you
Oops... forgot to update the overview page. Should be all set now.
  #166
Old June 23rd, 2017, 01:48 PM
MrMxyzptlk MrMxyzptlk is offline
Z-Seer +
I have just installed the latest version for multiple networks, and I ran it for both of my Z-Nets.
My first Z-Net has 43 nodes all fully optimized with good or excellent communication, Z-Seer only found 3 nodes.
My 2nd Z-Net has 34 nodes all fully optimized with good or excellent communication, Z-Seer only found 5 nodes.
Is Z-Seer working properly, or am I doing something incorrectly?
  #167
Old June 23rd, 2017, 01:53 PM
It works fine for me. Can you post a screen shot. You sure its not just hidden?
Are you on the latest z-wave plugin version also?
  #168
Old June 23rd, 2017, 02:09 PM
Do you mean hidden in ZSeer or Homeseer?
Yes, I always stay on the latest plugins...I'm on 131
Never mind, I just ran it again to take a screen shot, and noticed the very last log message.
Trial version only shows 4 devices max...woops, I will enter my HS3 license.
  #169
Old June 23rd, 2017, 03:08 PM
macromark's Avatar
Do you have your PC's system fonts set to "LARGE" or are you scaling things up? I assume that's what is going on in your case.
  #170
Old June 24th, 2017, 03:08 AM
abwyatt's Avatar
abwyatt abwyatt is offline
Hmmm ... I am on 3.0.0.40 with a licence. Running on Windows 10 and connecting to a HomeTroller SEL/SmartStick+. Z-Wave plugin is 3.0.1.131
Problem is I am not seeing the Actions part of the interface at the bottom of the application window. Only Device Details are showing.
Any idea what the problem might be?
Andrew
  #171
Old August 21st, 2017, 12:37 PM
skavan skavan is offline
Seer Plus
Is it a bug or is it me? Groups and Z-Seer.
I have so many z-wave devices that I have painstakingly put them into groups (using @Jon00's excellent helper utility).
Now, none of the grouped z-wave devices show up in Z-Seer.
Only the ungrouped interfaces show up!
This is either a bug (grouped status should not interfere with z-wave topology) or maybe something I'm missing at my end. Whether a z-wave device is in a group or not should make no difference to z-seer behaviour -- and the z-wave plugin still sees all my devices just fine.
Please advise.
  #172
Old August 21st, 2017, 04:34 PM
rjh's Avatar
rjh rjh is offline
Not sure what you mean by "groups"? Did you just use one of the locations for groups? Can you post a screen shot of your device management page?
Please advise.
  #173
Old August 21st, 2017, 05:08 PM
Seer Plus
Groups of Devices -- with a parent.
See attached.
  #174
Old August 21st, 2017, 06:16 PM
rjh's Avatar
rjh rjh is offline
Hmm, you are doing something you are not suppose to do! Device parents are the parent for one physical Z-Wave device. You are grouping multiple physical devices under one parent. This really breaks a lot of stuff and I would not do that. I cannot put in a fix to support it with Z-Seer. You should the device location to group your devices together. What we do at times is use location 2 as a category and location 1 as a room. This organizes devices pretty well.
See attached.
  #175
Old August 21st, 2017, 06:46 PM
Seer Plus
That's a shame. I have been using HS for years, and now, in my new smarthome with hundreds of devices, the lack of tagging options is my single biggest buggaboo. I only resorted to Groups because they do a nice job of just that Grouping devices. There are just not enough slots to store metadata and then use that metadata for device management and scripting.
My personal wishlist is:
  1. A few user defined fields that can store metadata for each device
  2. A tree view that can go Category>Room>UserDefined or UserDefined>Room>Category and so on.
  3. devices grouped in a GUI group with an expand/contract icon [just like I wrongly did -- but with the ability to expand and contract]. When you have large numbers of complex devices (receivers, tv's, sonos) and hundreds of z-wave devices, management and navigation becomes really, really, painful.
Right now, for example, I have resorted to using the notes field to store a delimited set of metadata that I use with my own custom Alexa Skill (so that when I say, Alexa, "turn on the bedside lights", it knows that the Alexa is in Bedroom 1 and there are two bedside lights in Bedroom 1 and it does its thing. So in my notes field I have Bedroom 1|Bedside Lamp. My Lambda loads all the devices and reads the field, handles the location stuff and then barks commands at all the devices with matching tags. It would be so much easier if there were 10 (or n) user defined fields for stuffing Tags into.
The core of homeseer is stupendously good...but a few little things like the above would make a huge huge difference.
  #176
Old August 22nd, 2017, 11:41 AM
rjh's Avatar
rjh rjh is offline
We are working on some changes to make organizing easier.
Note that we did add a "Voice Command" field to the devices so you can enter your custom voice command for any device, and Alexa uses this. Might help with what you are doing with Alexa.
  #177
Old August 22nd, 2017, 11:51 AM
Seer Plus
Thanks...don't want to corrupt this thread too much...
But -- I see a voice command checkbox -- but (a) I don't see a payload field (for the custom voice command) and (b) is this field, sent in json in response to a device list query?
  #178
Old August 22nd, 2017, 12:21 PM
rjh's Avatar
rjh rjh is offline
The textbox is in the latest beta, load the beta from the HS3 beta forum. This build should be released in a week or so.
  #179
Old September 10th, 2017, 08:24 PM
rmorton27's Avatar
rmorton27 rmorton27 is offline
Where oh where does one find z-seer+ download/installer?
A bit confused. Can't seem to locate an install for z-seer+, feeling a bit incompetent.
  #180
Old September 10th, 2017, 09:53 PM
rjh's Avatar
rjh rjh is offline
https://homeseer.com/current-downloads/
New Z-Seer+ For HS3 macromark Z-Seer+ 12 September 6th, 2017 05:02 PM
