Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > Z-Seer+
Z-Seer+ Discussions about Z-Seer+ Z-Wave Network Diagnostics Software
Old June 16th, 2017, 11:31 AM
whoamib whoamib is offline
Z-seer+ only sees one Z-Net device
I have run z-seer+ on my cabin network and it only polls from one Z-Net device, after trying to disabled and disconnect that device, it just errors out. I read that it can only read from one controller, but not only is it not switching to the other controller but the controller it is reading from only gives me 1 device when I know there are 4 devices
Here are the errors I get when opening z-seer+, these devices are on the controller that I can't connect to using z-seer+:
Skipping device Cabin GarageCabin Garage Camera Appliance Module since its Z-Wave node ID is 0
Skipping device Z-WaveAeon Labs Repeater Slave since its Z-Wave node ID is 0
Skipping device BunkhouseVision Sec Notification Sensor since its Z-Wave node ID is 0
Skipping device Z-WaveVision Sec Notification Sensor since its Z-Wave node ID is 0
Skipping device Z-WaveAeon Labs Repeater Slave 12 since its Z-Wave node ID is 0
Old June 16th, 2017, 11:43 AM
sparkman's Avatar
sparkman sparkman is offline
This thread has info on that: https://forums.homeseer.com/showthread.php?t=189382. Bottom line is that it currently does not work with multiple controllers. HS is working on a new version that does.
Cheers
Al
Old June 16th, 2017, 12:09 PM
Thank you!
Sent from my SM-G935V using Tapatalk
Old June 19th, 2017, 11:21 AM
integlikewhoa integlikewhoa is offline
Just to update this. That is now fixed on the newer version.
Old June 19th, 2017, 12:31 PM
Your right it is working now! Thank you for the update!
Z-NET LED Never Stops Blinking and HomeSeer Pro Never Sees it Jeron Z-NET 13 December 16th, 2015 07:12 PM
8 Button KPLs. HS only sees 6 gjtherk@comcast.net Insteon Plug-in (Mark Sandler) 5 March 25th, 2013 08:30 PM
Correct X10 PRO XPD3 Home Seer Device Type? JSBatch Lighting & Primary Technology Discussion 6 December 10th, 2011 05:19 PM
HS2 "sees' change by another PLM SESamuels Insteon Plug-in (Mark Sandler) 1 December 20th, 2010 04:44 PM
