Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > Z-Seer+
Z-Seer+ Discussions about Z-Seer+ Z-Wave Network Diagnostics Software
Old June 28th, 2017, 07:55 PM
gregoryx gregoryx is offline
Battery devices shown as non-battery
I'm digging the diagnostics here! Helping me see things I couldn't see previously.
On that note, I've been setting up MS6 and other battery devices in non-battery mode just because it's easier and faster. Then pull the plug and put in the batteries. Now I'm seeing that HS thinks they're non-battery devices. Any way to change that without removing / re-adding the devices?
If I have to remove the device, is there a way to do it at the Z-Wave level then re-bind them to the HS device so I don't have to rebuild everything (events and HS Touch, etc) that is associated with the HS devices?
RF Devices Low Battery? PJJPtx Vista Alarm Plug-in (3P) 5 November 30th, 2016 01:56 PM
UltraM1G3 Wireless zone low battery trouble detected but not shown correctly LeoS UltraM1G HSPI 2 May 30th, 2016 06:10 AM
Polling battery devices mikedr HomeSeer Z-Wave Plug-in 0 February 13th, 2015 04:05 PM
Fed-Up with Z-Wave battery devices sooty HomeSeer Z-Wave Plug-in 4 February 22nd, 2014 08:57 PM
