Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > Z-Seer+
Z-Seer+ Discussions about Z-Seer+ Z-Wave Network Diagnostics Software
Old December 28th, 2017, 12:22 PM
GadgetBoySI's Avatar
GadgetBoySI GadgetBoySI is offline
No scroll bars?
I do not see the scroll bars on my installation. Because of this, I cannot view the actions section or the map of my entire network.
Has anyone else experienced this?
LazyAutomation
www.lazyautomation.com
la·zy [ley-zee] - Resistant to work or exertion; disposed to idleness.
au·to·ma·tion [aw-tuh-mey-shuh n] - The automatic operation or control of equipment, a process, or a system.
HS3Pro / HSTouch / JRMC 19 / Gizmo / M-Audio Delta 410 / 5 Zone Whole House Audio / UPB / ZWave / RFXCOM / Windows 7 HTPC / Ceton InfiniTV w/Xbox Extenders / W800
Old December 28th, 2017, 02:29 PM
Rupp's Avatar
Rupp Rupp is online now
Try using View > Reformat Nodes and see if this solves your issue.
-Rupp
Old December 28th, 2017, 11:54 PM
Yeah, Matt recommended I try that when I was on the phone with him yesterday and it didn't work. I figured I would check in here to see if anyone else had the issue and how they solved it.
Thanks.
LazyAutomation
Old May 8th, 2018, 09:49 PM
gnichols gnichols is offline
Seer Plus
Any solution?
I'm having the same problem.
Old May 8th, 2018, 10:18 PM
rmasonjr's Avatar
rmasonjr rmasonjr is offline
Originally Posted by gnichols View Post
Any solution?
Can you change your screen resolution?
concord 4 water detector and window bars TeleFragger Security System Discussion 1 June 28th, 2012 07:37 PM
I hid the menu bars top and bottom ... Isk82 HomeSeer General Discussion Area 2 May 16th, 2012 04:05 PM
Title bars in WinMo won't go away Kamikaze HSTouch™ 1 December 30th, 2008 01:11 AM
Bars around Menu items that do not have a submenu. cerjzc DooMenuBar Plug-In 4 February 11th, 2007 08:54 AM
