Interface not found error
    I installed the plug-in 2.0.12.0 added the IP address of the Roomba
    I get an error I can't seem to make go away..any thoughts on what I'm missing?
Name:	crack o dawn.jpg
    Devoir
    Is this Linux or Windows?
    Cheers,
    Bob
      Blade thanks for the update, I'm on a Windows platform
      Current Date/Time: 1/10/2018 10:37:59 AM
      HomeSeer Version: HS3 Pro Edition 3.0.0.318
      Operating System: Microsoft Windows 8.1 Pro - Work Station
      System Uptime: 0 Days 0 Hours 3 Minutes 26 Seconds
      IP Address: 192.168.199.208
      Number of Devices: 551
      Number of Events: 188
      Available Threads: 400
      Enabled Plug-Ins
      2.0.49.0: BLBackup
      2.0.12.0: BLRoombaWifi
      3.0.0.75: HSTouch Server
      3.0.0.25: ImperiHome
      3.0.6.0: Insteon
      2.0.1.6: JowiHue
      0.0.0.35: Pushover 3P
      3.1.0.18: Sonos
      3.0.6542.35207: UltraWeatherWU3
      3.0.1.130: Z-Wave
        That is odd
        Have you tried restarting HS3? Do you still see that error?
        Cheers,
        Bob
          REboot
          Blade,
          1 Shutdown HS3
          2 made backup of entire HS3 directory
          3 Rebooted Laptop with HS3
          4 Rans HS3 as "administrator"
          Error still exists...
          Devoir
            Log
            Blade,
            is there any log file or details I can send to help trouble shoot this?
            Devoir
              Do this:
              1. Shutdown HS3
              2. Edit the hspi_BLRoombaWifi.ini file in the config folder and change debugLevel=true and save INI file
              3. Restart HS3
              Once HS3 has been started for a minute or so go to the options page in the plugin and disable debug logging
              Attach the BLRoombaWifi-Detailed.log file zipped
              It is in the HS3 root folder
              I will check and see if there are any errors
              Cheers,
              Bob
                Log file
                Blade many thanks I changed the hspi_BLRoombaWifi.ini statement = true
                I also noticed there were more than one Roomba.ini files in the screen shot. I only edited this one..
                I am attaching the log file
                BLRoombaWifi-Detailed.txt
                Devoir
                  Your Blid and password does not look correct
                  Did you use dorita to get them?
                  Have you checked this thread
                  https://forums.homeseer.com/showthread.php?t=191518
                  Cheers,
                  Bob
                    roomba password
                    Blade,
                    The only thing i did was install your plug-in.......
                    I thought that was all that was required....
                    I will go to the Dorito site and try to follow it
                    Devoir
                      Dorita980 Success
                      Blade:
                      Many thanks for the direction:
                      I was able to follow your instructions. I installed a windows version of Node.js and NPM.
                      I also discovered when I set a static IP the password changed to something else..... thought that was interesting
                      I was able to add the Roomba and now can control from this Plug-in....
                      Appreciate this
                      Devoir
