Old January 12th, 2018, 06:42 PM
hunter69 hunter69 is offline
Seer Plus
Ibeacon Major Minor
I have been researching the purpose for the Major Minor setting. I have not found a thread that clearly explains the purpose of the Major Minor Setting.
Also
How does a person pick the ID?
Old January 12th, 2018, 06:57 PM
cheeryfool's Avatar
cheeryfool cheeryfool is offline
Super Seer
Quote:
Also
The major/minor settings allow you to differentiate easily between beacons. You will usually find that if you buy multiple beacons from the same manufacturer, they will all come configured with the same long UID and with both major/minor set to 1. This is for ease of manufacturing. If you buy more than one to use in the same vicinity you'll want to be able to differentiate between them. Setting the major/minor settings to different values achieves that. I have 3 beacons currently. They are configured: Major1/Minor1, Major1/Minor2, Major1/Minor3
There is no need to change the long UID, though you usually can if you wish.
cheeryfool
Old January 12th, 2018, 07:06 PM
Seer Plus
Thank you for the help.
If you don't mind I need to check my setup for Ibeacon.
I am using geofency. I added my ibeacon into geofency.
I added a user in phlocation for the ibeacon. I added the ibeacon uuid into the phlocation tab in the user in phlocation.
Does that sound like I am doing this correctly?
Bill
HTML code is Off
Apple Watch - Geofency - iBeacon teladog01 PHLocation Plug-in (3P) 1 February 16th, 2017 12:27 PM
Minor Nit zwolfpack APCUPSD Plugin (3P) 1 September 4th, 2016 09:08 AM
