Does anyone know why the plugin might not be controlling Stargate relays? This is a new install (trial) for a friend. They work on my setup, but for some reason Homeseer can't change the relays.
Public Sub Main(ByVal Params As Object) Dim intRval As Integer Dim oSG As Object = hs.Plugin("JDS StarGate") intRval = oSG.ThenMacro(18) End Sub
