Post them here. Please include a descriptive use-case so that I can get a better understanding of the how/why the feature is being requested. This description and your thought process will help me to figure out how possibly best implement.
Feature Requests
Stacking groups and varying group tile widths
Wayne
I love the new look and thanks to Sputnik also for the suggestions.
A couple more requests from me:
1. Would it be possible to stack groups to use up vacant space. e.g. If I have a General group with just the clock and weather widgets, that takes up 2 tiles wide by 3 tall. There is perhaps room for another 2x2 tiles below. If I have a Locks group (only 2 locks) it would fit nicely below the General group.
2. Groups all seem to be a double tile wide currently. If I have 2 thermostats, it would be nice to have the option to stack them within the group in a single tile width. Similarly I have a whole load of devices in a group and it would be great to make this group 3 tiles wide, to save them scrolling off the bottom of the screen.
Cheers
Jamescheeryfool
Cheers
James
Originally posted by olag00 View PostI dont believe I have seen this requested in the main thread but would it be possible to select a background image or change the color other than black?
Sputnik, those are pretty solid.
As for another feature request, from my post in the main thread, could we get a "webpage" tile for a single site as well as keep the multiple site tile?
For my purpose I will only have one webpage needed for each tile but I dont want to remove the multiple site tile if people are using it that way.
Thank you.
Thank you.
Originally posted by sputnik View PostDesign polish & slick animations
Thermostat:
(Tapping on the tile turns the thermostat on to cool, then heat, and then finally back to off). The underline animation means the thermostat is working/loading)
Small tile (using touch):
Small tile (using mouse):
Originally posted by wposner View PostYou don't have to configure multiple sites to the webpage tile. You can do a single site. So I'm assuming you're not liking the three second delay. But that's consistent behavior with all tiles and gives you a three second safety buffer to change your mind in case you accidentally tap the wrong tile.
So maybe the feature would be a "no delay tile" and a "3 sec tile"???
Originally posted by olag00 View PostYou are right in the 3 second wait is a little long for me I am more of a now kind of user I thought maybe it was a delay in the proxy server when I would activate lights, thermostat, etc.
So maybe the feature would be a "no delay tile" and a "3 sec tile"???Last edited by wposner; July 10, 2015, 03:37 PM.
I have some virtual devices that have values and associated pics with them - they basically control radio stations and tv channels by different means. If the device changes, it triggers an event to change the station/channel to what is needed.
So, one device is 0-10, the other 0-40+. The standard device control is ok, but it's a bit tiresome to change to the correct channel - if you make a mistake and go one channel too far, you can end up having to press another 40+ times.
Could we have a device type that is similar to the format of the tstat, two tiles vertical or horizontal, status pic, with two buttons to go up/down the values please?
Originally posted by Furious View PostI have some virtual devices that have values and associated pics with them - they basically control radio stations and tv channels by different means. If the device changes, it triggers an event to change the station/channel to what is needed.
