Z-Wave Interface Backup Script
    #46
    Originally posted by TechFan View Post
    Mine is empty.
    OK, here is an easier alternative than using CPAN:
    sudo apt-get update
    sudo apt-get -y install libwww-perl
    (I should have known there was a better way than how I've been doing it for the past 20 years!)
      #47
      sudo apt-get update
      Lol. Glad you found it! Thanks!
      Anything I can safely do to address (remove/repair) what appears to be broken CPAN?
      Installed libwww-perl
      root@HomeTrollerZeeS2:/usr/include/arm-linux-gnueabihf/sys# apt-get install libwww-perl
      Reading package lists... Done
      Building dependency tree
      Reading state information... Done
      The following extra packages will be installed:
        libencode-locale-perl libfile-listing-perl libfont-afm-perl libhtml-form-perl libhtml-format-perl
        libhtml-parser-perl libhtml-tagset-perl libhtml-tree-perl libhttp-cookies-perl libhttp-daemon-perl
        libhttp-date-perl libhttp-message-perl libhttp-negotiate-perl libio-socket-ip-perl
        libio-socket-ssl-perl liblwp-mediatypes-perl liblwp-protocol-https-perl libmailtools-perl
        libnet-http-perl libsocket-perl liburi-perl libwww-robotrules-perl
      Suggested packages:
        libdata-dump-perl libcrypt-ssleay-perl libauthen-ntlm-perl
      The following NEW packages will be installed:
        libnet-http-perl libsocket-perl liburi-perl libwww-perl libwww-robotrules-perl
      0 upgraded, 23 newly installed, 0 to remove and 150 not upgraded.
      Need to get 1,198 kB of archives.
      After this operation, 3,413 kB of additional disk space will be used.
      Do you want to continue [Y/n]?
      And, btw, the script worked this time. . .I have a .ZWave backup file! :-)
        #48
        [QUOTE=TechFan;1295074]
        /QUOTE]
        Try to upgrade it and see if that fixes it.
        After you 'sudo cpan' if your are not root, run the following within the CPAN shell:
        install CPAN
        reload cpan
        Len
        HomeSeer Version: HS3 Pro Edition 3.0.0.435
        Linux version: Linux homeseer Ubuntu 16.04 x86_64
        Number of Devices: 633
        Number of Events: 773
        Enabled Plug-Ins
        2.0.54.0: BLBackup
        2.0.40.0: BLLAN
        3.0.0.48: EasyTrigger
        30.0.0.36: RFXCOM
        3.0.6.2: SDJ-Health
        3.0.0.87: weatherXML
        3.0.1.190: Z-Wave
          #49
          Glad you got it working!
          The problem isn't with CPAN, but with the C-compiler. All the #include <sys/*.h> files are missing. Best guess is that the Homeseer build excluded them or deleted them purposfully/accidentally. Only effect would be if you want to build anything from c-source (including of course any perl modules that have c-source components).
          To fix, determine the package that installs the include files, then remove & reinstall it:
          sudo apt-get -y remove <package>
          sudo apt-get -y install <package>
          Not sure how to determine the package unfortunately.
            #50
            K. Thx. I just wasn't sure if I needed to clean up all that installing that module tried. Otherwise, will leave alone for now.
              #51
              I was getting a '401 unauthorized' error.
              When I disabled the option 'No Password Required for Local/Same Network Login' (in network settings)
              the scripts works great, only I rather don't disable this setting. Do you know a workaround (running HS on a debian server)?
              Or is the only option to adjust the script with something like this Perlmonks.org
              -- Edit --
              I've been trying several things like create an url with userassword@IPServer but that doesn't work
              I've adjusted the original script
              #!/usr/bin/perl
              # Z-Wave backup utility
              # d. g. otto 2016/01/25
              # usage: zwbkup.pl [ hs3_host [ formid ... ] ]
              use strict;
              use warnings;
              use English;
              use POSIX qw(strftime);
              use LWP::UserAgent;
              use HTML::TokeParser;
              use HTML::Entities;
              # the default filename starts with an identifier of the interface type
              # guessing for most of these
              my %IFMdlPfx = (
                  0  => "None",        # None,
                  1  => "ZNet",        # HomeSeer Z-NET Ethernet
                  4  => "SmartStick",  # HomeSeer SmartStick +
                  6  => "ZWaveMe",     # Z-Wave.me UZB
                  2  => "ZStick",      # Aeon Labs Aeotec Z-Stick
                  5  => "ZTroller",    # HomeSeer Z-Troller
                  8  => "HomeProZC",   # ACT HomePro ZC Series
                  11 => "ThinkStick",  # ControlThink ThinkStick
                  14 => "AspireUSB",   # Cooper Aspire USB
                  17 => "AspireRFUSB", # Cooper Aspire RF-USB
                  19 => "SmartStick",  # HomeSeer SmartStick Legacy
                  20 => "CA8700",      # Intermatic CA8700
                  23 => "HA22",        # Intermatic HA22
                  25 => "SigmaUZB",    # Sigma Designs UZB
                  29 => "WDUSB10",     # Wayne-Dalton WDUSB-10
                  32 => "Serial",      # Generic Serial Controller
                  35 => "ZNet",        # Ethernet Interface
              # current timestamp portion of backup file name
              my $now = strftime("%Y-%m-%d_%H.%M.%S", localtime);
              # cmdline parameter 1: HS3 host
              my $host = shift;
              $host ||= 'localhost';
              my $url = "http://$host/ZWaveControllers";
              my $user = 'admin';
              my $pass = 'password';
              my $ua = LWP::UserAgent->new();
              $ua->agent("USER/AGENT/IDENTIFICATION");
              # cmdline parameter 2+: form id(s) to process
              my @formids = @ARGV;
              @formids = get($url) unless @formids;
              print "Form ID(s): ", join(",", @formids), "\n";
              foreach my $formid (@formids) {
                  # 1st time selects action "Back Up this interface"
                  get($url, $formid);
                  # 2nd time sets the filename and submits the START button to perform the backup
                  get($url, $formid);
                  sleep 2;
                  # this seems to keep it happy...
                  post($url, [ action => 'updatetime' ]);
                  sleep 1;
              my (%friendly, %homeid);
              sub get {
                  my ($url, $formid) = @ARG;
                  print "GET $url\n";
                  my $request = HTTP::Request->new(GET => $url);
                  $request->authorization_basic($user, $pass);
                  my $rsp = $ua->request($request);
                  print $rsp->status_line, "\n";
                  exit unless $rsp->is_success;
                  my $content = $rsp->as_string;
                  my $p = HTML::TokeParser->new(\$content);
                  my ($form, $select, $optval, $submit, $text, @postdata, %p);
                  my ($friendly, $homeid, $tcol);
                  my @formids;
                  while (my $tok = $p->get_token) {
                      my @tok = @$tok;
                      my $op = shift @tok;
                      if ($op eq 'S') {  # tag Start
                          my ($tag, $attr, $attrseq, $origtext) = @tok;
                          my %attr = %$attr;
                          if ($tag eq 'form') {
                              # form name
                              $form = $attr{name};
                          } elsif ($tag eq 'input') {
                              if ($attr{type} eq 'text' and $attr{name}) {
                                  if ($attr{name} =~ /^Friendly_([0-9A-F]+)/) {
                                      # parse the Networks and Options form for
                                      # Network Friendly Name and Home ID
                                      $homeid = $1;
                                      $friendly = $attr{value};
                                      $tcol = 1;  # table column number
                                  } elsif ($attr{name} =~ /^NewName_[0-9A-F]+/) {
                                      # Interface Name
                                      # available for use when building the backup file name
                                      $p{IFName} = $attr{value};
                                  } elsif ($attr{name} =~ /^File_[0-9A-F]+/) {
                                      # set the backup file name as appropriate
                                      my $filename = $attr{value};
                                      $filename = generate_filename($filename, %p);
                                      push(@postdata, $attr{name} => $filename);
                          } elsif ($tag eq 'select') {
                              # name of select pulldown form field
                              $select = $attr{name};
                          } elsif ($tag eq 'option') {
                              # an option within a select form field
                              $optval = $attr{value};
                              if ($attr{selected} and $select =~ /IFModel_/) {
                                  # index of selected Interface Model
                                  $p{IFModelIndex} = $attr{value} || 0;
                          } elsif ($tag eq 'button') {
                              # submit button
                              if ($attr{name} =~ /^GO_[0-9A-F]+/) {
                                  # submit the form
                                  push(@postdata, %attr);
                      } elsif ($op eq 'E') {  # tag End
                          my $tag = shift @tok;
                              # end of form - post queued changes
                              if ($form and $form =~ /^Form_([0-9A-F]+)/ and @postdata) {
                                  my $thisid = $1;
                                  push(@formids, $thisid);
                                  if ($formid and $formid eq $thisid) {
                                      post($url, \@postdata);
                              undef $form;
                              undef @postdata;
                              undef %p;
                              undef $select;
                              # end of option - text label is available for query
                              if ($select =~ /^OpSelect_/ and $text =~ /back\s*up/i) {
                                  # set action to 'Back Up this interface';
                                  push(@postdata, $select => $optval);
                              undef $optval;
                          } elsif ($tag eq 'td') {
                              # table data
                              if ($tcol and $tcol++ == 4) {
                                  # Interface Name is in 4th column of table displaying
                                  # Z-Wave Networks and Options
                                  my $ifname = $text;
                                  $friendly{$ifname} = $friendly;
                                  $homeid{$ifname} = $homeid;
                                  undef $tcol;
                      } elsif ($op eq 'T') {  # Text
                          ($text) = @tok;
                          $text =~ s/[\r\n]//g;
                          $text =~ s/^\s+|\s+$//g;
                          $text = decode_entities($text);
                  return @formids;
              my %submit;
              # POST the changes
              sub post {
                  my ($url, $postdata) = @ARG;
                  my @p = @$postdata;
                  # don't submit same button more than once
                  my %p = @p;
                  if ($p{name}) {
                      return if $submit{$p{name}};
                      $submit{$p{name}}++;
                  print "POST $url\n[\n";
                  for (my $ii = 0; $ii < @p; $ii += 2) {
                      print "  $p[$ii] => $p[$ii+1]\n";
                  print "]\n";
                  my $rsp = $ua->post($url, $postdata);
              # routine to generate the backup file name
              # default behaviour is
              # {IFModel}_{FriendlyName}_{HomeID}_{TimeStamp}.ZWave
              # customize as desired
              sub generate_filename {
                  my ($givenname, %p) = @ARG;
                  # interface name
                  my $ifname = $p{IFName};
                  my $friendly = $friendly{$ifname};
                  # HomeID
                  my $homeid = $homeid{$ifname};
                  # map interface model index to abbreviation defined above
                  my $idx = $p{IFModelIndex};
                  my $mdlpfx = $IFMdlPfx{$idx};
                  # build the darn thing!
                  my $newname = "${mdlpfx}_${friendly}_${homeid}_${now}.ZWave";
                  return $newname;
              And the get actions are good but I can't figure out how to fix the post function with authentication.
              s# perl /etc/HomeSeer/scripts/zwbkup.pl
              GET http://localhost/ZWaveControllers
              200 OK
              Form ID(s): EFB94519D6C8
              200 OK
              POST http://localhost/ZWaveControllers
              OpSelect_[DELETED] => 24
              401 Unauthorized
                #52
                Good point, I'll take a look at adding this in.
                  #53
                  Thank you in advance. I've been reading Perl and trying several things but I'm not that good in programming.
                    #54
                    I've updated the base post with 'r3' to provide this capability. The username & password can be hardcoded into the file, or provided via command line option -l username/password:
                    perl zwbkup.pl -l username/passwd
                    Let me know how it goes...
                      #55
                      Nice, thank you very much, that was realy fast.
                      The new script works great. I've hardcoded the username and password in the file and chown/chmod to adjust the rights.
                        #56
                        Base post updated to revision 'r4' which adds a retry mechanism. In installations with more than one interface, the process would sometimes not generate one or more of the backups. With the retry mechanism, all the backups generate properly.
                          #57
                          This one now works with all 3 interfaces and no longer needs a plug-in restart between each directly addressed backup as had to be done with prior versions.
                            #58
                            Great, thanks for testing!
                              #59
                              Thank you @zwolfpack
                              I was able to install perl on my minipc and it executed the backup perfectly and even has the date and time. Life is good.
                                #60
                                Not Getting Backup File From Event Execution
                                Hi zwolfpack,
                                Thank you for the backup script. I always like to automate things when possible. I'm on Windows 7 (32-bit) embedded (HomeTroller). When I found your script, I setup a test event to try it out (after installing Perl). However, I don't see any output. I assume that the backup would go to the same location when running the task manually:
                                > C:\Program Files\HomeSeer HS3\Data\Z-Wave
                                I read through the thread, and saw several references to the user name and password, but I'm not clear what those should be. I did try the default "homeseer" Windows logon name and password, but that didn't work. Maybe it's something else?
                                I can see that the event recorded in the log (see screen shot), but I only see 2 entries which occurred when I clicked the execution button and nothing further.
                                Are the username and password required entries for the r4 script?
                                I'm a complete newb, so I'm sure it's something I've setup incorrectly. Appreciate any suggestions on how to ensure it's working!
                                Dave
