I am considering getting a Z-Wave USB interface "stick" that I would use for adding nodes to my existing HomeTrollerZeeS2V2, as well as updating the firmware on some devices like an Aeon Labs Multisensor 6.
Currently when I need to add a node that is hard-wired, I am powering down my HomeTrollerZeeS2V2, then powering it by a battery and taking it to the node to add. I would like to use something more portable like a USB stick so I don't have to power down, restart, power down again, etc.
I also want to be able to update the firmware on devices like the Aeon Labs Multisensor 6. I understand I would need to plug the USB stick into a Windows machine to do the firmware updates.
Can the USB stick interfaces be used for adding nodes remotely then copying the nodes to my HometrollerZee?
Can I use one USB stick for both uses (adding nodes and updating firmware)?
Which products would be good for this purpose?
Dave
HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.368
Dave
