Attached is version 2.0.0 beta 1 of the SqueezeBox plugin. The major goal for this release is HSTouch support, though it includes a few other enhancements. This is a first version toward HSTouch support and I am looking for feedback! I tried a few HSTouch screens but I am sure you will
come up with other variations, library sizes and usage pattern that will provide valuable feedback.
New features
Bug Fixes
This is Beta software! Backup before installing the attached beta update. This Beta software should be installed on top of the currently released plug-in available from the updater. Once installed, do not forget to update the SqueezeBox Server plugin using the Extension Downloader.
NOTE 1: I updated the plug-in to version 2.0.0.2. This version creates MusicAPI instances for disconnected players and also uses a different approach to collect information about the current song and especially the artwork. Still some work to do regarding support of some character sets and noticed that HS Touch once a while does not update the arwork while the cached image has been updated.
I also highly recommend you update to HSTouch server plugin 1.0.0.12 (see http://board.homeseer.com/showpost.p...16&postcount=1 for details).
NOTE 2: I updated the plug-in to version 2.0.0.3. This version corrects a problem when new players are added and when searching the library when non ASCII characters are used (note that these searches are slower that others for now due to a SB Server query issue).
New features
Bug Fixes
