I just recieved my Rain8upb yesterday. I connected it to the computer and assigned the zones the correct codes and such per the instructions. When I use the communication test software from WGL, I can turn the valves on and off.
It is assigned module number 30 which gave the zones ID# of 233 thru 240. I then setup placeholders in UPStart per the sintructions for UID 233 thru 240. When I open HS, the placeholders are showing in HS (codes \57 thru \64), but if I click ON or OFF, nothing happens and the log shows "UPB Retry count exceeded UPB Message transmission failed."
Am I missing something here that I should have done to get this to work?
