so I was able to find that Hstouch was unable to run due to Rss data not loading. This has been working for the last year. I guess there is no error catching for this as I left Hstouch designer loading and it took around 1/2 hour.
Then I shutdown Hs3 425 and then started the Hstouch designer, got the connection error, then loaded the project and removed my screen with the Rss feeds.
Then started Hs3 425 and the Hstouch designer started up immediately no waiting.
I will try to find out if these feeds are dead ends, and should there be a timeout because if links go dead the whole program stops running.
Stuart
Stuart
