All,
Following on from http://forums.homeseer.com/showthread.php?t=181427 I have written a plugin for the DoorBird doorbell units (https://www.doorbird.com/). THIS IS A HS3 PLUGIN.
NOTE RE HOMESEER HS4 - https://forums.homeseer.com/forum/ho...80#post1327880
It is a reasonably simple plugin and will exploit most of the available commands from the LAN API.
Any issues/concerns/suggestions please post them to this thread and I will try and resolve, please read the documentation however.
Download
Please download this via the HS3 updater
Release Notes
0.0.0.7 - 01/08/2016 - Fixes as per post #34 - Appears stable
0.0.0.9 - 26/08/2016 - Minor amendment to live streaming page to use new API method to access the MJPG stream, also fixed minor bug in enabling/disabling this page
0.0.0.10 - 24/12/2016 - Added option to date/time stamp a downloaded image, also changed the method to determine whether or not the DoorBird unit is online
0.0.0.12 - 27/12/2016 - Fixed connection status issue, added ability to browse images on drop list that are in the images directory
0.0.0.15 - 08/02/2017 - Added configuration option for event retrigger time, increased device reset timeouts, included a method to check corrupt images
0.0.0.16 - 18/02/2017 - Added option to disable debug for Linux installs, fixed repeated logging to console window
0.0.0.18 - 24/04/2017 - Removed DoorBird Motion notifications from the HS log, caused excessive log traffic
0.0.0.19 - 18/08/2017 - Added option for motion sensor image download - needs 3D motion sensor enabled
0.0.0.20 - 24/03/2018 - Changes for new DoorBird API versions, legacy matters removed
0.0.0.21 - 31/03/2018 - Fix for bug with users needing HS login details to be passed to DoorBird
0.0.0.23 - 17/11/2018 - Fix for relay/open devices in HS not staying for 5s, fix for older firmware units
0.0.0.24 - 22/06/2019 - Added option to restart the DB unit with an event action
Documentation
Please see attached to this post
Download
Release Notes
Documentation
