Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > HiTec Homes Plug-Ins > Rain8Net
Rain8Net Discussion area for the Rain8Net plug-in by Hi-Tec Home
Old July 1st, 2009, 10:26 AM
jromanowski jromanowski is offline
Seer Plus
Restart?
It appears that if I restart HomeSeer Server, I need to unplug/plug to reset the Rain8Net units or they will not respond to commands. Is there a way around this? Is this expected behavior?
Old July 1st, 2009, 01:17 PM
lpitman's Avatar
lpitman lpitman is offline
Seer Master
That is not normal behavior...the plug-in shuts down the serial port using standard DotNet calls. I would suspect the serial port off the cuff, with out knowing your setup.
-Larry
A member of "The HA Pioneer Group", MyWebSite
WHS 2011 Server - SageTV, HS 2.2.29 with 9TB Shared Hard Disk.
Plugins:
Ocelot, MitsubishiTV, DenonAVR, DirecTV, DVDMovies, HAI-Thermostat, HAI, Hauppauge, lrpSpeak, MediaPlayer, Rain8Net, Sprinklers, UIRT, VWS.
Hardware:
Intel 3.0Ghz CPU with 12Gb. Ram and 2Tb SATA HD. Davis Inst. VantagePro II, AB8SS, Rain8Net, RC80 Thermostat, OmniProII, Ocelot, X10, UPB, HD-200 Extenders.
HTML code is On
