HSPro: v2.5.0.23
VWS Plugin: v2.2.0.32
VWS: 14.01p46
I have the good ol' original 2.2.0.0 which was free and works perfectly on my old setup. But I'd like to support the effort here and I'm willing to purchase the plugin but my initial experience here isn't very promising.
1) Regardless of what changes I make on the configuration page they are never saved.
2) The variables are never properly created, I only get maybe 1/2 of them and recreate appears to do nothing.
3) Someone else already mentioned the warnings the call to "status" being depreciated in the HS log.
So what's the status of this plugin, the forum seems to be active. This is a clean install on Windows 7 64-bit....
here is all I have from the vws.log:
Thanks.
- Jeff
VWS: 14.01p46
PHP Code:
12/19/2011 9:27:06 PM ~******************************************
12/19/2011 9:27:06 PM ~VWS*** Debug Enabled.
12/19/2011 9:27:06 PM ~VWS*** Logging to AppDirPath\Logs\VWS.log.
12/19/2011 9:27:06 PM ~VWS*** HS-Version: 2.5.0.23
12/19/2011 9:27:06 PM ~VWS*** Plug-In Version: 2.2.0.32
12/19/2011 9:27:06 PM ~VWS*** gDayLast: 19
12/19/2011 9:27:06 PM ~VWS*** gMonthLast: 12
12/19/2011 9:27:06 PM ~VWS*** gHighTemp: 0
12/19/2011 9:27:06 PM ~VWS*** gLowTemp: 0
12/19/2011 9:27:06 PM ~VWS*** gCSVPollInterval: 5
12/19/2011 9:27:06 PM ~VWS*** gDBasePollInterval: 1
12/19/2011 9:27:06 PM ~VWS*** gWarningInterval: 1
12/19/2011 9:27:06 PM ~VWS*** gSpeakCount: 0
12/19/2011 9:27:06 PM ~VWS*** gCSVPath: C:\vws\data\
12/19/2011 9:27:06 PM ~VWS*** gDBasePath: C:\vws\data\
12/19/2011 9:27:06 PM ~VWS*** gUseWarning: True
12/19/2011 9:27:06 PM ~VWS*** gWarningPath: C:\vws\data\warning\
12/19/2011 9:27:06 PM ~VWS*** gSpeak: True
12/19/2011 9:27:06 PM ~VWS*** gPreSpeakStr: Attention, weather warning.
12/19/2011 9:27:06 PM ~VWS*** gMetric: False
12/19/2011 9:27:06 PM ~VWS*** gScaleValues: True
12/19/2011 9:27:06 PM ~VWS*** gReadCSV: True
12/19/2011 9:27:06 PM ~VWS*** gReadDBase: True
12/19/2011 9:27:06 PM ~VWS*** gLastWarningTime: 1/1/0001 12:00:00 AM
12/19/2011 9:27:06 PM ~VWS*** gNumTimesToWarn: 2
12/19/2011 9:27:06 PM ~VWS*** gMinutesBetweenWarn: 15
12/19/2011 9:27:06 PM ~VWS*** gNightStopTime: 10
12/19/2011 9:27:06 PM ~VWS*** gMorningBeginTime: 7
12/19/2011 9:27:06 PM ~VWS*** ZoneName1: VWS Data Status
12/19/2011 9:27:06 PM ~VWS*** ZoneName2: Weather Advisory
12/19/2011 9:27:06 PM ~VWS*** ZoneName3: Wind Speed
12/19/2011 9:27:06 PM ~VWS*** ZoneName4: Wind Gust
12/19/2011 9:27:06 PM ~VWS*** ZoneName5: Wind Direction
12/19/2011 9:27:06 PM ~VWS*** ZoneName6: Inside Humidity
12/19/2011 9:27:06 PM ~VWS*** ZoneName7: Outside Humidity
12/19/2011 9:27:06 PM ~VWS*** ZoneName8: Inside Temp
12/19/2011 9:27:06 PM ~VWS*** ZoneName9: Outside Temp
12/19/2011 9:27:06 PM ~VWS*** ZoneName10: Barometer
12/19/2011 9:27:06 PM ~VWS*** ZoneName11: Total Rain
12/19/2011 9:27:06 PM ~VWS*** ZoneName12: Daily Rain
12/19/2011 9:27:06 PM ~VWS*** ZoneName13: Hourly Rain
12/19/2011 9:27:06 PM ~VWS*** ZoneName14: Weather Conditions
12/19/2011 9:27:06 PM ~VWS*** ZoneName15: Channel 1 Temp
12/19/2011 9:27:06 PM ~VWS*** ZoneName16: Channel 1 Humidity
12/19/2011 9:27:06 PM ~VWS*** ZoneName17: Channel 2 Temp
12/19/2011 9:27:06 PM ~VWS*** ZoneName18: Channel 2 Humidity
12/19/2011 9:27:06 PM ~VWS*** ZoneName19: Channel 3 Temp
12/19/2011 9:27:06 PM ~VWS*** ZoneName20: Channel 3 Humidity
12/19/2011 9:27:06 PM ~VWS*** ZoneName21: Evapo Transpiration
12/19/2011 9:27:06 PM ~VWS*** ZoneName22: UV Index
12/19/2011 9:27:06 PM ~VWS*** ZoneName23: Solar Radiation
12/19/2011 9:27:06 PM ~VWS*** ZoneName24: Wind Chill
12/19/2011 9:27:06 PM ~VWS*** ZoneName25: Inside Heat Index
12/19/2011 9:27:06 PM ~VWS*** ZoneName26: Outside Heat Index
12/19/2011 9:27:06 PM ~VWS*** ZoneName27: Dew Point
12/19/2011 9:27:06 PM ~VWS*** ZoneName28: Rain Rate
12/19/2011 9:27:06 PM ~VWS*** ZoneName29: Outside Temp Rate
12/19/2011 9:27:06 PM ~VWS*** ZoneName30: Inside Temp Rate
12/19/2011 9:27:06 PM ~VWS*** ZoneName31: Barometer Rate
12/19/2011 9:27:06 PM ~VWS*** ZoneName32: Channel 1 Temp Rate
12/19/2011 9:27:06 PM ~VWS*** ZoneName33: Channel 2 Temp Rate
12/19/2011 9:27:06 PM ~VWS*** ZoneName34: Channel 3 Temp Rate
12/19/2011 9:27:06 PM ~VWS*** ZoneName35: High Temp
12/19/2011 9:27:06 PM ~VWS*** ZoneName36: Low Temp
12/19/2011 9:27:06 PM ~VWS*** ZoneName37: Monthly Rain
12/19/2011 9:27:06 PM ~VWS*** ZoneName38: Yearly Rain
12/19/2011 9:27:06 PM ~clsWebLink1--->GenPage() called with: /vws_config
12/19/2011 9:27:09 PM ~Entering....ProcessCSVData()
12/19/2011 9:27:09 PM ~Reading CSV C:\vws\data\\data.csv
12/19/2011 9:27:09 PM ~Updating Wx from CSV file
12/19/2011 9:27:09 PM ~WinDir: 223
12/19/2011 9:27:14 PM ~Entering....ProcessCSVData()
12/19/2011 9:27:14 PM ~Reading CSV C:\vws\data\\data.csv
12/19/2011 9:27:14 PM ~Updating Wx from CSV file
12/19/2011 9:27:14 PM ~WinDir: 223
12/19/2011 9:27:19 PM ~Entering....ProcessCSVData()
12/19/2011 9:27:19 PM ~Reading CSV C:\vws\data\\data.csv
12/19/2011 9:27:19 PM ~Updating Wx from CSV file
12/19/2011 9:27:19 PM ~WinDir: 222
12/19/2011 9:27:19 PM ~Updated device: _5 to 222░ SW; value set to 22200
12/19/2011 9:27:24 PM ~Entering ShutdownIO()...
Thanks.
- Jeff
