Pete - Did you receive any input from others? Any decision on which way you guys want to go? Cheers - Gary
HS3 HAI Linux Plugin Status
Hello Gary.
No I did not.
That said tell me what you think about the "sneak peak" of the plugin. It is currently connecting to the panel just fine. We have devices, DB and logging.- Pete
October, 2013
Thinking out loud here and proposed looking for feedback....
Next steps relate to beta testing and including participants.
That said a running linux device including beta plugin to HAI panel distributed to contributors.
The plugin would be running in Linux and connecting to HS3 whatever its running on.
Database for plugin will be mysql which can reside local or remote to Linux device.
Baby steps here .....
Initially.....
Most important before anything else is to watch is speed of local DB logging concurrent to networked transport and variables to the mothership (HS3 Logging) and response times from HS3 interface to Linux plugin. This will relate initially to status only and then manual changes.- Pete
Pete,
Coming into this late, but some questions.
Since this is software based I Linux any reason I couldn't run it in a virtual machine on the same computer as HS3?
Also, I would like to run UPB through the panel due to the 2 way feedback (and the fact HS3 has UPB listed as an "eventual" driver which means who knows what functionality or timing on that it will have. Does the driver allows control of UPB through the panel v HS3 directly?
Still needing donations?
Questions...
Pete,
Also, I would like to run UPB through the panel due to the 2 way feedback (and the fact HS3 has UPB listed as an "eventual" driver which means who knows what functionality or timing on that it will have). Does the driver allows control of UPB through the panel v HS3 directly?
Here is a link to the OmniPro II owners and installation manual
http://www.homeauto.com/Downloads/Pr...Manual_3-2.pdf
http://www.homeauto.com/Downloads/Pr...nManual3-2.pdf
We are OK with donations / acquisition of test panel.
The "test" panel and accessories has been purchased and is in the hands of Rob Mason.
That said a donation right now would go into the funding monies above which can provide more testing hardware for Rob and will provide a testing piece of embedded linux hardware with software plugin already running for beta testing.
A HW and SW widget to plug into the HAI panel via a network connection. (still in the "thinking out load stage" asking for input).
A lesser donation would provide you with a test / participation beta plugin which will be released shortly. (IE you could then create your VM and install the beta plugin on your VM).Last edited by Pete; October 18, 2013, 11:54 AM.- Pete
Guest
Originally posted by abazin View PostJust noticed this thread. I have an omni LT. Would this plugin work with that panel?HS4Pro on a Raspberry Pi4
HSTouch Clients: 1 Android
Guest
Originally posted by rmasonjr View PostWe're getting closer to releasing a general beta release. When its available, you can try the plugin to see if it will connect. So far, we have only tested with an OPII.
I don't have an LT to test with, so I can't be sure. No, the source code will not be available.
Sent from my SCH-R970X using TapatalkHS4Pro on a Raspberry Pi4
Guest
If I buy the plugin because it does work with the LT and then 1 month later it stops working........I am a developer so if I knew I could help fix bugs related to the LT then I would be interested in buying. However with no LT testing/support and a closed source model it would be hard to justify buying.
Originally posted by abazin View PostIf I buy the plugin because it does work with the LT and then 1 month later it stops working........I am a developer so if I knew I could help fix bugs related to the LT then I would be interested in buying. However with no LT testing/support and a closed source model it would be hard to justify buying.
No other plugins offer source code, except for HST plugins. You can purchase the HAI plugin from HST and modify it to suit your needs, but it is a serial-based plugin.HS4Pro on a Raspberry Pi4
Guest
