Jon00 Homeseer/Echo Skill Helper for Homeseer 3 & Homeseer 4
    Thanks, I'll take a look at that one.
    Jon
      Originally posted by Blade View Post
      Jon,
      Is there a way to pass the text after "Alexa, tell HomeSeer to" as a script parameter?
      I would like to further process the speech text in a script for certain things
      You can do this in check_vcmd.vb script. The Data parameter carries this text.
      Jon
        I see Data parameter in check_vcmd.vb script but how do I use that in the ScriptParm= for the trigger?
        Maybe I am missing something obvious
        Cheers,
        Bob
          Sorry I thought you wanted to do your own thing. I did think about passing the voice string to the script parameter but then I thought that as you had triggered it from the trigger match, there was not much point. I can see that there could be a use for this by having a simple trigger match which could be further parsed by a script.
          Very easy to add. I'll try and update this later today.
          Jon
            Awesome. Thanks Jon
            Cheers,
            Bob
              Version 1.0.3 is now available.
              Changes:
              Added method to pass the Alexa voice string through the script parameter.
              Updated wep page config page to deal with apostrophes in the text.
              If already installed, just update both .vben scripts.
              Jon
                Thanks Jon - will try it out tonight
                Cheers,
                Bob
                  I assume the PDF doc was updated to show what we need to do to pass the data through or does it automatically happen?
                  Cheers,
                  Bob
                    Yes, but all you do is add a * to the script parameter entry and it will then pass the voice string to the script.
                    Jon
                      @Blade.. what is the use case for wanting this? What does giving the voice string as a parameter provide other than an unparsed string.
                      Robert
                        Awesome. If no star is there or the ScriptParm value is missing does it still try and parse out the number in the alexa text?
                        Cheers,
                        Bob
                          That is correct.
                          Jon
                            HI all.
                            Jon00 - thank you so much - my Amazon Echo experience has improved 10 times over!
                            Could i get some assistance:
                            1) I have three events created in homeseer - i can see two of them, but the 3rd event cant be selected within your Helper page as an event.
                            2) I am battling to toggle certain devices on / off when using the simple device value or set device value functionality. I obviously get the correct device ref (for example 50) and have tried. 50,1 and 50,100 and 50,255 for Z-wave modules and other simple on off switches. I cant get anything to turn on or off.
                            Alexa is defintey recognising the commands but not sure if is sending through the right info?
                            "Nov-15 9:13:18 PM Jon00_Alexa Script processing time: 2 ms
                            Nov-15 9:13:18 PM Jon00_Alexa Response sent to Alexa: 'OK'
                            Nov-15 9:13:18 PM Jon00_Alexa Successful trigger under [Trigger6]
                            Nov-15 9:13:18 PM Jon00_Alexa Integer Parsed: -9999
                            Nov-15 9:13:18 PM Jon00_Alexa Alexa Number String:
                            Nov-15 9:13:18 PM Jon00_Alexa Alexa command heard: 'breakfast light on'"
                            Anything to try?
                              Looks like the first one is a bug. In the meantime you can type it in manually.
                              If you are controlling a Z-wave device, you should be using the CAPI entry.
                              i.e. if the device reference number is 1234 your entry would be
                              1234,0,on (for on)
                              1234,0,off (for off)
                              1234,50 (for 50% dim)
                              Jon
                                Robert
                                I plan to use the full text in order to possibly do something with my Russound plugin
                                I plan to use a phrase like this:
                                Alexa, tell Homeseer to play pandora in the Great Room
                                I can then run a script to turn on the zone in the great room to the pandora source and start playing pandora. That is the goal
                                Cheers,
                                Bob
