Has anyone ever used this 1 wire LCD display?
AAG 1 Wire LCD
I'm planning on using a variable in my Ocelot and the IR interface to keep track of the preset station that my tuner is on. It is controlled via IR from HS/Ocelot and a SmartPad3 but since it is only controlled via up/down preset I should be able to have a variable in the Ocelot track the preset it is on. I would then like to use this LCD to display the current preset.
Jabran
AAG 1 Wire LCD
Jabran
