HI,
I have installed 2.3 with no issues so far apart from this UPNP error which reoccurs every minute or so. I have disabled UPNP in the HS setup and still get the error.
I do have UPNP running (as per the grc tool indicates from grc.com and can see other UPNP devices like routers etc) and have a valid ethernet IP address and a comprehensive local network running so not sure what HS cannot find.
FYI I have sever VMWARE machines also running, is it possible that HS is no finding the service because of multiple netwok adapters?
Also Nortons AV running, Windows XP SP2.
Phil
14/11/2008 2:13:06 PM - Warning - UPNP Discovery is not running, most likely your PC does not have a valid IP address, will try to enable later: An attempt was made to access a socket in a way forbidden by its access permissions
14/11/2008 2:13:06 PM - Warning - If this system is not on a network, disable UPNP in Setup.
Phil
