Been using the .19 version for some time and all was good. Was updating some events to set temperatures which were working fine. Then HS stopped being able to set the temperature on the Nest. Its reading everything and updates if I change the Nest on the web or iphone app but HS3 wont control it. I updated to the .20 beta version to see. No change. Rebooted HS and also toggled the plugin. No success.
What do you suggest? I did turn the debug on for the log and its attached..
