I had been successfully using the Nest Plug-In with the NET4 patch since 11/30/16, but it appears to have frozen up. The Nest thermostat is working fine and is not locked. Following is the Debug Log and System Profile:
Debug Log:
DEBUG data: {"path":"/","data":{"devices":{"thermostats":{"gi6tL1If6Gh4sKtsxRKsgw_ VumSUMP-v":{"humidity":35,"locale":"en-US","temperature_scale":"F","is_using_emergency_heat":false, "has_fan":true,"software_version":"5.6-7","has_leaf":false,"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTGEY2KDrCGVSQ","device_id":"gi6tL1If6Gh4sKtsxRK sgw_VumSUMP-v","name":"Family Room","can_heat":true,"can_cool":true,"target_temperature_c" :21.0,"target_temperature_f":70,"target_temperature_high_c": 24.0,"target_temperature_high_f":75,"target_temperature_low_ c":20.0,"target_temperature_low_f":68,"ambient_temperature_c ":20.5,"ambient_temperature_f":69,"away_temperature_high_c": 24.0,"away_temperature_high_f":76,"away_temperature_low_c":2 1.0,"away_temperature_low_f":70,"structure_id":"Z7b9qYp7jyNF ztUkn8KoK2C6R5W-QBA8olUNDeeMxmUBm_XPeD_NQA","fan_timer_active":false,"fan_ti mer_timeout":"1970-01-01T00:00:00.000Z","hvac_mode":"heat","name_long":"Family Room Thermostat","is_online":true,"last_connection":"2016-12-06T06:01:41.895Z","hvac_state":"heating"}}},"structures":{"Z 7b9qYp7jyNFztUkn8KoK2C6R5W
System Profile:
Current Date/Time: 12/6/2016 10:05:26 AM
HomeSeer Version: HS3 Pro Edition 3.0.0.297
Operating System: Microsoft Windows Embedded Standard - Work Station
System Uptime: 5 Days 21 Hours 33 Minutes 36 Seconds
IP Address: 192.168.1.113
Number of Devices: 61
Number of Events: 13
Available Threads: 200
Enabled Plug-Ins
3.0.0.68: HSTouch Server
3.0.0.19: Nest
3.0.0.11: NetCAM
3.0.1.87: Z-Wave
Debug Log:
System Profile:
Enabled Plug-Ins
3.0.0.19: Nest
3.0.0.11: NetCAM
3.0.1.87: Z-Wave
