I have an RCS ZCV4 with 2 active zones on my M1G - latest version of the plugin, latest HS3 - seems to work fine stand alone. But now I'd like to control the thermostats via a HSTouch thermostat graphic, but I'm stumped.
The only control option I see for the setpoint devices is to set to a specific temperature. I don't see a way to increment/decrement setpoints by one degree, as you would on a thermostat. Is there a way to increment/decrement? Workaround? Script command? Can this feature be added?
Similarly, is there a way to toggle Mode (toggle between Heat/Cool/Off/Auto), toggle Fan (Auto/On/Off), and toggle Hold (Auto/Hold)?
I'd like my graphics to duplicate the way the real wall control works. Thanks for any help.
Mark
Mark
