What do I do with redundant "devices"?
eg: each fibaro relay/dimmer I have (in total 9 I think) has a Switch Binary 2 which is not used. Only Switch Binary is used which I now rename to "room" light eg: Bedroom Light or Office Light.
So can I hide or do something with Switch Binary 2?
Equally, what happens to what I call the master device that sits at the top of each grouping of device (where you can set the z-wave protocols etc)
In many cases it's not too bad but in others, there are so many which almost need to be grouped up so all the power management stuff should go into it's own area, all the switches into another, etc.
Strangely in some cases, the last update status for the "redundant device" was yesterday even though nothing is connected to it or rather it doesn't do anything for example:
Switch Binary 2 = redundant. Last updated: Today 07:07:08
Switch Binary (Now renamed to Shower Light) = the actual on/off switch that controls something shower light. Last updated: Today 07:07:08
Both are updated with the same date/time yet Switch Binary 2 does nothing at all.
Thanks in advance
Thanks in advance
