Just an FYI, if you plan to use the Insteon hub and Mark's plugin you will need to disable Mark's plugin if you want to create scenes from the Insteon App.
I really like how the scenes are done in the app and noticed an issue once I moved Mark's plugin over to using the hub as a modem.
