What Randy said is correct. The device reset is done in the device, so the sensor reset itself then notified all attached devices, in this case the Z-NET controller attached to HS. This reset is handled by the firmware in the Z-NET which is code that is not public, Sigma only gives us a binary of that code. So there is no way we could stop this from happening. You might contact Aeon and see if there is any other way the device would remove itself from the network. I am not aware of any. The feature is for manually removing a node when the controller does not offer, or cannot offer a remove feature.
Note that I think with that sensor if you hold the button down a long time, it is removed. Maybe someone pressed the button and held it too long?
Originally posted by BobSpen
View Post
